Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven door will not unlock after self cleaning
Oven door locked
  • trsax Oct 01, 2008
    All of a sudden "oven door locked" is flashing on the display, and the oven doesn't program. I can still open the oven door though.
  • openoven Dec 03, 2008
    i realized after i set cleaning that i had something with plastic inside can not open oven door
I have a GE profile Spectra Gas oven and went to clean it yesterday and the door will not unlock. What can I do? Please advise . Thank you, Zeedancer
Posted on Nov 24, 2008
I had the same problem, and after about a month of troubleshooting, I finally found the problem. There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch solved my problem.
To reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. Mine was located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch. You should fee a click.
Reassemble and power up.
Posted on Oct 09, 2008
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
Oven door remains locked after using the oven cleaning feature
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 12, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
2,304 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
