Question about Epson 2580 Perfection Photo Scanner
Cannot communicate with the scanner
When I try to start my EPSON Perfection 2580, I get the comment: Cannot properly communicate with the scanner. I've checked all cables, tried different USB cables, uninstalled, re-installed software, updated drivers etc.
One thing that's happened is that in the middle of the installation, I get a comment: Can't find Appinst.ini
  • 4 more comments
  • Anonymous Nov 07, 2008
    I have the same problem
  • Anonymous Dec 20, 2008
    Bought new epson Stylus NX100 Series All in one printer.
    I connected it to scan the documents. Then i get the following error message
    "Cannot properly communicate with the scanner. Make sure
    the scanner is on, properly connected, and properly set up to scan. If using
    a SCSI connection, restart your computer."
    I rebooted my m/c & made the connections correctly But still gets the same error message.
  • enduser101 Jan 02, 2009
    I have the same problem running vista and a Epson gt 2500
  • Anonymous Jan 17, 2009
    Same problem with my epson perfection 2580 on my new computer which has vista
  • Anonymous Mar 06, 2009
    I have the same problem ...help!!!
  • Paulo Garcia
    Paulo Garcia Nov 26, 2013
    me too!!!!!!!!! (epson workforce 435)
  • 4891 Answers
SOURCE: epson perfection 2580 scanner will not start
The first thing to try: a new USB cable and a different port. (If you are using a hub, try directly connecting to the computer). What does the device manager say about the scanner? (In Windows, access from the Control Panel > Hardware. Exact directions depend on the OS version.)
Check the transport lock on the bottom of the scanner - do not put the scanner on its side when you check the lock.
Make sure the scanner was on and had already warmed up (stopped blinking) before you tried to start the scanner software (either by the buttons or from the scanner). You may want to reboot the computer (in case the computer thinks one program has locked access to the scanner).
I hope this helps.
(scanners require two-way communication with the computer and a bad cable will stop the scan even when the computer sees the scanner and the software installed without a problem.)
Posted on Apr 26, 2010
How do you scan a slide on an epson 2580 scanner? It's scanning like a photograph not a slide.
You need the slide attachment, Read the Manual by clicking below.
Epson Manual
And the adapter should be included in the box which you purchased
Regards,
Ron
Feb 08, 2011 | Epson Perfection 2580 Photo Flatbed...
Epson perfection 2580 scanner will not start. Programs installed w/cd. Epson updates added. Just says" scanner can not start"
I hope this helps.
Apr 26, 2010 | Epson 2580 Perfection Photo Scanner
I have a 2580 Epson Scanner and for some reason can't work with my Mac Pro, Can you please help me?
hi there, it may be that Epson hasn't developed drivers compatible with your system. My suggestion is to try it on another computer that has windows and see if it works. If so, go on Safari and type in Epson Perfection 2400 Photo Flatbed scanner drivers and see what comes up on Epson's website.
Jan 20, 2010 | Epson Perfection 2400 Photo Flatbed...
I have an epson 2580 it now produces somewhat
The only way you're going to know if it's the scanner or the driver for sure is to install it on say an XP machine and see what results you get. If it's still dark, it's the scanner, if not, it's the driver.
Dec 15, 2009 | Epson 2580 Perfection Photo Scanner
My epson scanner 2580 photo won't do anything, it is connected
plz try by reloading the drivers then change the port and usb cable
Nov 06, 2009 | Epson 2580 Perfection Photo Scanner
File settings dialog box is too high on screen to read, doesn't drag down
Go to the display properties of your computer and change the resolution.
Goodluck.
sherlyn c.
May 22, 2009 | Epson Perfection 2580 Photo Flatbed...
I need installer in this scanner
i dont have the cd for install the scaner (epson-2580 photo) please help me. thank.
Nov 18, 2008 | Epson 2580 Perfection Photo Scanner
Epson 2580 scanner
The only thing I can think of is to turn you to be scanned image up side down in the scanner bed.. IE Rotate 180' As another work arround simply open up Paint etc,and rotate the image 180' and save, ya should be all good.
Feb 16, 2007 | Epson 2580 Perfection Photo Scanner
Epson 2580 Perfection Photo Scanner  Logo
1,123 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
