Question about Kenmore 24032\24036 Top Load Washer
Kenmore elite top loader electric washer
My washer fills with water but does not begin to wash. Sometimes if I pick up lid and shut it hard it clicks and begins to wash. But now that doesn't even work. Any suggestions?
  • 32 Answers
You have poor contact with the left lid hinge and the lid switch.1st open the lid and check the 2 phillips head screws on the left side of the hinge.if they are loose tighten them and try mach.if the screws are tight,the lid switch might need to be replaced or adjusted.there will be 1 screw in each corner of the back of the console facing down.remove and flip console up,if there are no screws,take a putty knife and slide under front left and right corner of console and flip console up.the lid switch will be on left.if it is not broken out of socket,adjust hinge bar underneath switch by removing switch and bending silver bar up SLIGHTLY
Posted on Sep 28, 2008
Kenmore Elite Washer will not fill wash basket with water.
It's either a water supply issue or an electrical supply issue..
If it's a water supply issue, check the hose screens at the inlet hoses. Shut the water off to the machine, and take the hoses loose at the faucets. Take the screens that are in the hose end out and clean them, then reinstall.
If it's an electrical issue, you won't get any response from the machine when you start it.. not sure if this is your case, but the first place is to check the circuit breaker and reset if needed. Then check the lid switch operation. This switch will keep water from flowing if it's not properly operating. Sometimes the lid on a washer can get slightly bent by too much weight be placed on the machine. Open and close the lid and listen for a positive "click" from the micro switch.
Those are good things to check for a start...let us know if you still have a problem with your kenmore.
Jul 29, 2009 | Kenmore Washing Machines
I have a Kenmore Elite top loader that does not agitate after its filled with water and the lid is shut. I've tried all speeds.
I had the same problem with my Kenmoore and had to replace the agitator...ordered the part through Sears. Wasn't hard to fix, just needed to wait for the shipment.
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Top Loader
try different temp settings be sure screens in inlet valve end of hoses are clean and taps on all the way if you gave water to washer and still none coming in suspect bad fill valve
Sep 03, 2008 | Kenmore 24032\24036 Top Load Washer
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
56 people viewed this question
Sal De
 Brian Main
Brian Main
