Question about Kenmore 63942 Dryer
KENMORE DRYER PART NO 696891
MY DRYER WILL STILL HEAT UP WHEN I TURN IT ON, BUT IT WILL NOT TURN. DO YOU HAVE ANY IDEA WHAT COULD BE THE PROBLEM? IF SO, IS IT SOMETHING I CAN FIX MYSELF?
  • 1 more comment
  • sarahscissor Oct 01, 2008
    Our dryer also won't turn and we discovered the belt had broken on it- got a new belt but now can't figure out how to get it all back together...any ideas???
  • mrtazz Oct 24, 2008
    my 70 series dryer when turned on will heat but the drum won't turn,belt seems ok and drum and belt will turn by hand tho?
  • oq316 Nov 30, 2008
    I have a Kenmore Dryer that comes on gets hot, but does not turn. It will however manually turn by hand. What is the problem?
My dryer keeps breaking the belts for no reason. I am going to take it outside and beat it with a 10 LB sledge hammer and set it on fire!
Posted on Nov 27, 2008
  • 550 Answers
Kenmore dryers, are easy to work on, they all come apart from the front, so you dont even have to drag them out from the wall
most likely cause of no tumble is a broken belt, the belt costs $7 (or what the parts store guy thinks he can get away with) there are really only 5 belts among all the different brands and models of dryer so the parts guy will have one, even if it is labelled with a different manufacturer name it Will fit.
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reinstall cabinet front and lid in reverse order
~15 minutes, but I do 3-4 every day
Posted on Oct 08, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore Dryer
What is the model number of your unit?
Nov 26, 2012 | Kenmore Dryers
Kenmore gas dryer no heat, have cleaned all components with shopvac and rags, still no heat, spins and all seems good, geta little warm once out of every 30 times i turn it on, any idea's?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 03, 2011 | Kenmore 73102 Gas Dryer
I just replaced the motor in my Kenmore Series 90 dryer, When I'm running the dryer with no heat it runs as quite as could be expected for a ten year old dryer, When I run with heat the dryer starts making...
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Feb 14, 2010 | Kenmore 659 Electric Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
My dryer will not turn off or heat? ideas
Seems you have 2 problems.
1. Bad thermal fuse located on the heat canister on the top left side.
2. Bad heating element. shorted out.
Remove the back panel to access these parts.
Remeber to unplug the dryer.
Mar 10, 2009 | Kenmore Dryers
are you sure belt not broke remove screws under lint screen and pull top up by releasing clips under edge each corner..is motor running ? also belt may have jumped off idler pulley and motor pulley remove front panel to ck
Oct 24, 2008 | Dryers
Kenmore 63942 Dryer Logo
566 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
