Question about Cameras
Panasonic mini dv cassette door started to open then stopped and cassette stuck. Camera keeps asking to push reset button.
I took it in for repair.
Posted on Oct 04, 2008
When i rewind it comes up with press the reset button
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
Jun 29, 2009 | Panasonic NV-GS25 Mini DV Digital...
The tapes In my Panasonic PV-GS14 are stuck and won't run
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
May 09, 2017 | Panasonic Palmcorder PV-GS14 Mini DV...
Panasonic Mini DV NV-GS11EG "push the reset button"
i know what to do next brother go to field or a soccer field and trow the bloddy thing away
Mar 25, 2008 | Panasonic NV-DS60 Mini DV Digital...
Stuck tape in camcorder
I had a similar problem with an older panasonic camera. Mybe you have tried this, but opening the door and pushing up on the tape. Push in and use enough force but don't try to break it. Try pressing different spots. Sooner or later the motor might start moving it up. Just a though, it worked for me.
Mar 18, 2008 | Panasonic PV-GS300 Mini DV Digital...
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
Push the reset button
Solution:
cassette housing
Hope this can help.
Jan 10, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
Door opens "Slightly"
I had the same problem, and TomInMB
told me how to fix it:
What I did was to first remove the battery and AC power to "reset" the camera. I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VOILA!
I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism. Good luck!
Walt D in LV
http://www.thecinemaniacs.com/
Jan 10, 2008 | Canon ZR65E Mini DV Digital Camcorder
Tape wont eject, play, or rewind. It tries, but soon the message to push reset comes up. No help. Camera works ok otherwise.
put the camera to your ear , power it up and listen ! if it sounds . . . jerky ? your tape is stuck to the heads ( not easy to get out , cassette may be toast and - time is money ) ; if you hear whirring sounds ? before shuts down your cassette housing may be bent ( will need disassembly etc . but not usually expensive ) because - if it is a loading problem , it will usually eject ;
Sep 04, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
Panasonic PV-GS31 won't FOCUS
Just a hunch as sometimes the micro will get scrambled so take off the battery as well as the battery or batterys for the date and time. and let the unit sit for 24 hours power back up as see if that cleared your error If not send away to get repaired.
Mar 27, 2006 | Panasonic PV-GS31 Mini DV Digital...
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
