Question about GE Kitchen Ranges
Oven will not turn on. Everything else works - GE Kitchen Ranges
Check both sides of breaker pair for continuity
see if breakers are properly straddling both busses
Posted on Sep 27, 2008
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
Timer is ok but oven not working
I understand that you are having trouble with your oven, model# CPLEF398DCE, not working/heating, even though the display screen is showing everything to be working fine. I suggest you give your appliance a hard reset. You will do this by switching the circuit breaker off, that the oven is on, for 3-5 minutes. Once the 3-5 minutes has passed, switch the circuit breaker back on. The first thing you will need to do, is to set the time. You will do this by entering in the time and pressing start. Turn the oven on. If you are still having trouble with the oven not working/heating, I suggest you contact your local authorized technician to come and diagnose the oven, to see why it will not work correctly.
-Best Regards-
Jan 19, 2014 | Frigidaire Ovens
My oven does not heat up. Everything else on the stove works (top burners, clock, timer, ect.) When you turn the oven dial, it even clicks as if it were to start the oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jan 10, 2011 | GE JGRP17 Gas Single Oven
Nothing is hot - everything is on
Check the door safefy interlock switches before you plunk your $ down.
If you open your oven to check the contents without turning the oven off first ... the tiny switches arc and start to burn ... once they cannot make contact ... the oven doesn't know if the door is open or closed so it will not turn on the heat.
It is worth checking ...
Jun 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
