Question about JVC HX-C6 Shelf System
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
Hi
i have JVC Hx-d7 dvd stero palyer that turn off itself after few minute showing PROTECT message on Display.
protect mode keeps coming on
  • 2 more comments
  • Anonymous Sep 29, 2008
    my JVC HX-D7 dvd stereo player will play for a minute and turn itself off and display the word protect.
  • laschatas83 Dec 05, 2008
    Do you have the same Problem?
    Please describe the specifics of your problem below. We'll add
    your post as a comment to dragnfli65's PROTECT message display on JVC HX-D7 DVD Stero Player and turn off problem, and notify you when a new solution is offered.
  • kimmyers Jan 30, 2009
    I have the same problem.My jvc stereo comes on and says protect and then shuts itself off
  • jackie Mar 13, 2013
    my jvc house streo turns it self off when i have turned it on any solution to fix my problem please
It was happening to me when i was beginning with maximum sound. u have to begin with normal or minimum sound,it will work normaly.I decrease the sound of my dvd player and protect message has gone.its works normally now.
je t'envoie à toutes fins utiles les coordonnées de notre voyage en Thaïlande
Posted on Jan 17, 2009
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Posted on Nov 23, 2008
Am looking for answer!!!!!!!!!!!!!!!
Posted on Dec 03, 2008
I had one that did the same i took it to the desert and shot ths **** out of it
Posted on Sep 29, 2008
    New Friend:
    Problem Solver:
  • 7 Answers
Just finished servicing the same unit. it was not in protect mode but was distorted for about 30 sec after startup and would occasionally distort while in use. i removed the upper power circuit board and located several bad connections which i resoldred. i also found a bad cap 100uf at 25v but i think the main problem was the connections. now it is working perfect.
Posted on Apr 13, 2013
  • Dan Coburn
    Dan Coburn Apr 13, 2013
    just finished servicing the same unit. it was not in protect mode but was distorted for about 30 sec after startup and would occasionally distort while in use. i removed the upper power circuit board and located several bad connections which i resoldred. i also found a bad cap 100uf at 25v but i think the main problem was the connections. now it is working perfect.
3 Suggested Answers
SOURCE: PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
I had the same problem with a jvc stereo set, it turned out the two cables of a speaker were touching each other.
Posted on Nov 30, 2007
check the golden wires in the back if they are touching then make them not touch and it should work
Posted on May 09, 2008
"PROTECT" message in display.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
I Have a JVC HX-07 that turns off itself after few seconds showing PROTECT message on display?
the unit may be damp inside.there is dew protection on most new units.It sometimes happens when units are used in the basement.unplug it and plug it back in again and see what happens
Jan 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
My jvc hx-d7 radio is turned on in 2 seconds it shuts down to protect mode how do i take protect off ?
You can't. The main amplifier module will probably have a channel blown. The unit is detecting this and tripping into protect mode to stop further damage occurring. Needs to go to a repair place. sorry. ps If you get sound briefly before it trips off then it may just be a speaker wire shorting out! worth checking
Nov 07, 2009 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
STERO SYSTEM
What happened to make it go into protect mode? was it dropped or something hit it? was there a power outage or storm in the area? or did it just go into protect all on it's own one day? If I have more info I may be able to help.
Feb 06, 2008 | JVC HX-D7 Shelf System
PROTECT MESSAGE
Most likely he has a couple of the connectors crossed. It is going in protect mode to keep it from damaging the internal electronics. Open it back up and double check all connections. then let me know.
Jan 07, 2008 | JVC HX-D7 Shelf System
"PROTECT" message
I've got a jvc hx-d7 i am working on for a friend, he had it repaired once at a shop with this same problem, they replaced two 42v 2200mf caps. and one A1273 this solved the problem for 8months now its doing it again. I am trying to locate the A1273 to repair it again. Hope this helps.
Dec 25, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC HX-C6 Shelf System Logo
2,318 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
