Question about Hunter 23852 Classic Original Ceiling Fan
Ceinlg fan I have a Hunter ceiling/light fan. The fan has Black,White and Black and White striped wires. The ceiling prewire has only white and black and ground, how do I connect the wires to be operable
If your house has only a black and white wire, than you need to tie the black, balack and white striped wire to the black of the hous. You than have to use the pull chains on the fan when the switch is on, to turn the fan or the fan light on or off. If youre house had a red wire than that would be tied in with the black and white striped wire and you would have two swithes on the wall to control the fan and light instead of having to use the pull chains.
Posted on Sep 27, 2008
How to attach and wire my controller for my remote control
What model do you have? If it is an add-on remote, then follow instructions here:
1) Black on end of receiver to black in ceiling.
2) white ( next to black ) to white in ceiling.
3)Other White to white in fan.
4) Black to black in fan.
5)Red or black w/ white stripe to blue or black w/ white stripe.
Oct 16, 2013 | Hunter 52" Ceiling Fan With Light And...
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
Im installing a remote to Hunter fan w/light. A White n Black coming from fan, Remote has Red,Black,White n Black n White to go to ceiling.Where do the red,black n white from remote go to on the fan? Thank...
Black goes to the black on the fan white goes to the white on the fan and the red will go to the blue wire on the fan for lights. Now if you have a black wire with a white stripe on it from the fan that is the light wire.
Apr 20, 2011 | Hunter (25417) Ceiling Fan
What is the whirring diagram
Most fans have 3 wires usually a white, black, and a blue(or black with white stripe) the white wire is the neutral and goes to the white wire in the ceiling box, the black wire is the fan hot lead and goes to the black hot lead in box and the blue(or other blk/wht) is for the lights and would go to the switched lead in the ceiling box(sometimes another color but not white or green)..if you don't have a switched lead coming out of the ceiling box and just two wires then the white goes to the white in the ceiling and both black and blue go to the black wire in the ceiling box
Jan 22, 2011 | Hunter 21617 Palermo Ceiling Fan
Hunter ceiling fan
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
May 03, 2010 | Hunter 27187 Remote Control
Wiring a ceiling fan with light fixture. there is a black and white stripe wire, one black wire, one white wire and ground wire. Coming out of the ceiling is two black and one white. one copper. please...
The black and black with white stripe are for the light and fan respectfully. The white wire is your neutral. That leaves the ground to your copper ground wire. If you have two seperate switches to operate the fan and light then the two black and black with white will tie in to seperate black supply wires. If only one switch then they will tie in together to the black supply wire.
Sep 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Bought a hunter remote and can't figure out what wires to connect
The remote red wire should go to the black wire that goes to the light. The remote black wire should go to the black or black with white stripe wire to the fan. The white wire should go to both white wires from the light and fan.
The power in (black and white) should be connected to your power source black and white. Bare copper wire to ground on fixture
Jun 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling Fan Electric
hi,
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
good luck, and be careful
J
Aug 06, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Hunter 23852 Classic Original Ceiling Fan Logo
115 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
