Question about Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive
Clean harddrive and re-install factory softwear
My computar over the years has runned very slow and I'm having trouble using my USB port or ethernet connection to synch my smartphone and Verizons DSL router...my computer wont pick up the routers IP address
Please help
  • 104 Answers
Run your recovery cd, that will bring your system back to factory spec
Posted on Nov 15, 2008
I am trying to install a printer to in my Dell Inspiron laptop 1545. I have the printer connected to the laptop through the ethernet port. But I can not get it to pull up the printer at all. Is the...
Hi lesstravelro...
No, the printer does not connect to the ethernet port.
Before you hook your printer to your laptop besure to run any softwear that came with the printer.
I would also recommend that you go to the Manufacturer's website for updated drivers for your printer.
Your printer will have a printer port or usb port on the side/back of the printer to plug the printer cable into the printer.
You will plug the other end of the printer cable into a usb port on your laptop.
Please take time to rate me thumbs up
Sep 21, 2011 | Dell Inspiron 1545 Notebook
Hi, I cannot connect my Lacie "EDmini Ethernet 400 gb" on to my laptop (dell with windows 7) via the Ethernet option? The blue light goes on but the disk cannot be found by my laptop. Could you...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 02, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Fujitsu Seimens PC about 5 years old - Ethernet connection?
are you trying to use two routers ?
about your pc it is almost sure that you have a ethernet port, don't know your system but look around and you may find it. also can use a usb ethernet adaptor, take the router to a friend house set it up with a diferent pc you will not be able to connect to internet there but if you set up everything, specially username and password ( PPPOE) when you come back home it will work. thats is you are replacing your older router.
can pm to me if have any further question
mendozaman@hotmail.com can look me up also on facebook
Jul 26, 2010 | Fujitsu Computers & Internet
Windows 7 is not recognizing and comes up as a cd drive?
then check.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Jun 22, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
Apple USB Ethernet suddenly not functional with mac book air
I've run into a similar problem myself. The problem could be that there is another device in the area using the same frequency and is causing interference. Try changing the frequency on your adapter. If you've recently added a wireless device and you can't change the frequency on your adapter try changing the frequency on the new device or turning it off to test if it's the problem.
It's possible someone else in the area has added a device that's causing the problem look around for new wireless devices or antenna in the area.
May 27, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
HP 4450 desktop, not have a ethernet port
No you can't.
But you have ywo other options to use broadband connection.
1. Use a USB modem, or
2. Install a network card to be able to use an ethernet cable.
A network card cost around $10.00.
Don't forget to rate this answer if it helps
Dec 27, 2009 | Computers & Internet
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite a205-s5831 Received kernel data error. Hard drive has clicking noises. Programs ran slow. Chkdsk running now for over 15 hours and only on 11%..preplacing bad clusters.
When a harddrive starts clicking it's on it's way out.
Buy a new harddrive and at the same time get a USB to laptop harddrive adapter. You can reinstall XP with the recovery disks that came with your machine ans then slave your old drive to your laptop and recover your personal files.
If you really want to get technicalbuy an Apricorn housing: http://www.newegg.com/Product/Product.aspx?Item=N82E16817155602
And two new harddrives, fit one new harddrive to the Apricorn housing and try to install the EZgig cloning software to your dying Windows. You can clone your existing Windows install to the new harddrive in the Apricorn housing and then move that drive to your laptop, the second new harddrive can then be fitted to the Apricorn housing and used as an external harddrive.
EZgig comes with the Apricorn housing and you could even go so far as to create a clone of your Windows install to the new external harddrive. The Apricorn housings are excellent, they are small enough to carry in your laptop case and all they need for power is a USB port.
Sep 01, 2008 | Toshiba Computers & Internet
Terrible slow internet connection after installing SP2
If you are sure it is a motherboard problem relating to the on board ethernet connection, purchase a PCI slot ethernet card and see if using the card manufacturers drivers are better than the motherboard ethernet drivers. Although i'm not sure how a slow connection is the motherboard problem, it maybe that it's SP2 thats the problem. Have you checked the driver that is used for the onboard ethernet connection, it maybe you need to re-install original motherboard ethernet driver you got with it.
Dec 07, 2006 | Albatron KX600S Pro Motherboard
Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
