Question about Logitech Cordless Rumblepad 2 Vibration Feedback Gamepad (GAMELOCRMBPD2)
Stuck toggle stick
My controller (Logitech Cordless) got left on the floor overnight on it's face and now it is stuck in the back position and nothing is working to un-stick it.The neutral position of the stick is making my character go in reverse. I took the batteries out and tried resetting, but nothing is working. Please help! Thanks
Eric
5 Suggested Answers
  • 10 Answers
SOURCE: Logitech Cordless Controller for Xbox not working.
it looks like you may have to change your controller for a new one
Posted on Nov 18, 2007
SOURCE: Gears of War for Vista and Logitech Rumblepad 2 directional issues (fwd/rev)....
you must edit the C:\Program Files\Microsoft Games\Gears of War\Engine\Config\BaseInput.ini and change the values from:
Bindings=(Name="XboxTypeS_A",Command="Use")
Bindings=(Name="XboxTypeS_B",Command="Jump")
Bindings=(Name="XboxTypeS_X",Command="ChangePosture")
Bindings=(Name="XboxTypeS_Y",Command="NextWeapon")
Bindings=(Name="XboxTypeS_LeftShoulder",Command="obj list")
Bindings=(Name="XboxTypeS_RightShoulder",Command="mem")
Bindings=(Name="XboxTypeS_RightTrigger",Command="Fire")
Bindings=(Name="XboxTypeS_LeftTrigger",Command="ToggleTargetingMode")
to
Bindings=(Name="XboxTypeS_B",Command="Use")
Bindings=(Name="XboxTypeS_A",Command="Jump")
Bindings=(Name="XboxTypeS_Y",Command="ChangePosture")
Bindings=(Name="XboxTypeS_X",Command="NextWeapon")
Bindings=(Name="XboxTypeS_RightShoulder",Command="obj list")
Bindings=(Name="XboxTypeS_LeftShoulder",Command="mem")
Bindings=(Name="XboxTypeS_LeftTrigger",Command="Fire")
Bindings=(Name="XboxTypeS_RightTrigger",Command="ToggleTargetingMode")
Posted on Jan 12, 2008
SOURCE: Logitech cordless Rumblepad 2
I purchased the Rumble-pad 2 controller but trying to get it to work with my Splinter Cell Pan... game seems impossible can you help?
Thanks,
CeeTee
Posted on Feb 05, 2008
IrishDruid
  • 2712 Answers
SOURCE: Logitech cordless desktop ex110
They should have an on/off switch on the underside that you can use to switch on/off...
Posted on Apr 17, 2008
Templarius
  • 83 Answers
SOURCE: Left-click of optical mouse is sticking
Yes open the mouse and clean the left click that should help if not is time to buy new mouse
Posted on May 26, 2008
My ps3 controllors left thumb joy stick gets stuck in the direction i push it in. It does not go back to its standard position unless i manually move it myself. i think it is just worn out but any...
This too happened to me before. What I found that if I repeatedly clicked the stick in, and slightly tugged on it, it would keep the stick from staying stuck in the one position. Hope this little trick works for you as well!
Mar 07, 2011 | Sony Wireless Controller for PlayStation 3
On cod my logitech controller's control pad moves my player but i cant move with the left joystick (they have been switched somehow)
You have to go through the game settings and ensure that you have set the primary control to be done by the left analog stick. In other words, make sure that you have the left-analog stick as the tool to move your player around while playing the game.
Also, if that doesn't work, there is a possibility that your left-analog stick is somehow jammed and as a result doewsn't perform the right function.
This could be a factory fault or one that arose as a case of mis-management. Whatever your result is, kindly let me know.
Hope this solution was helpful? Please comment for more information and thank you for using www.fixya.com
Jan 02, 2011 | Logitech Cordless Precision Controller for...
The left analog stick stuck to the left
You need to recalibrate the the analog sticks. To do this you need to take out one of the two batteries then press and hold L1 and L2 at the same time. While holding L1 and L2 insert the battery you took out earlier. Now you can release the L1 & L2 and your analog sticks should be centered. Do not touch or move the analog sticks during this process. If this fails to recalibrate then repeat the procedure again.
May 15, 2010 | Logitech Cordless Action Controller for...
We just recently purchased the wireless Logitech PS2 controller...my son has games which you can zoom in and out...but the controller is stuck ZOomed in and will not return to normal w/o having to pull one...
Mar 19, 2010 | Logitech Cordless Action Controller for...
How do you unlock the quikrelease when it is stuck open on the bosch recripcating saw
when you look at the front of the quick release, you should see 2 arrows, the arrow on the right faces up, the arrow on the left faces down. that is the open position, now all you need to do is insert a blade and it will lock closed by itself. then just turn it back to release the blade.
Jan 22, 2010 | Bosch 1646B 18V Cordless Reciprocating Saw...
Cordless Mouse Dell
Hi , your mouse is losing signal too the adapto that you plug into your PC , try putting it close , and change the batteries , this will help
Thanks
Dec 29, 2009 | Logitech Cordless Mouse
I bought a Sims 2 pet CD for PS2 and I need a manual to play.
The Sims 2: Pets
GAMEPLAY CONTROLS
Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships.
X Button Select. Action.
Triangle Button Cancel. Close Menu.
Square Button Pan Camera (Hold)
Circle Button Snap Camera to Sim
L2 Button Sim Switcher Menu (Hold)
L1 Button Freeze. Fast-Forward.
R2 Button Toggle Walls On/Off
R1 Button Freeze. Fast-Forward.
Start Button Pause
Select Button Toggle Control Mode
Left analog stick (L3 Button when pressed down) Move
Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS
X Button Place or Grab Object
Triangle Button Cancel. Back.
Square Button Remove Object and Put In Inventory
Circle Button Toggle Blueprint Mode
L2 Button Clone
L1 Button Rotate
R2 Button Undo/Redo
R1 Button Rotate
BUILD/REMOVE MODE CONTROLS
X Button Place/Remove Wall, Wallpaper, or Floor
L2 Button Clone Wallpaper or Floor
R2 Button Undo/Redo
Combo #1 L1 Button or R1 Button + X = Build or Fill Room
Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
acquired from (Gamefly.com)
Jul 06, 2009 | EA - Electronic Arts The Sims 2 Pets for...
Volume drops
um, it might be, simple or stupid, thought check the sides of the keyboard, the optional buttons, the volume down, might be stuck, hope it helps
=D
Feb 23, 2008 | Logitech Cordless Desktop S 510
Promblem
Normally there is no reason to re-calibrate the Logitech Cordless Action Controller for PlayStation2. In rare cases where the mini-joysticks may need to be re-calibrated, you can use the process below. Please note that this process only works for the Logitech Cordless Action Controller for PlayStation2.
  1. Remove one battery.
  2. Hold the L1 and L2 buttons while re-inserting the battery. (NOTE: Do not touch or move the mini-joysticks at all during this time. It is very important that the mini joysticks are allowed to center themselves during this step or the calibration procedure will not be successful.)
The mini-joysticks should now be re-calibrated. Please note that in some cases you may need to resynchronize the gamepad and receiver after this procedure.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=1414
Aug 13, 2007 | Logitech Cordless Action (9633200403) Game...
Logitech Cordless Rumblepad 2 Vibration Feedback Gamepad (GAMELOCRMBPD2) Logo
Top Logitech Video Game Consoles & Games Experts
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
