Samsung hln507W has turquoise blue color cast
The TV has turqouise blue in places where things should be shiny (people's foreheads and noses) and in the sky (instead of the normal blue). All other blue colors seem to be fine: blue jeans, blue hats, etc. The TV makes no loud noise, although a minor humming began to occur a couple of months ago (not audible above the tv audio).
  • AukCh00 Oct 05, 2008
    At this point, the TV also has red horizontal "noise" where black should be. Help! I just put in a new light because I thought that may have had something to do with it. One more thing...recently, the picture has been going off momentarily when I switch on/off a nearby light (all my lights are CFLs). I am attaching a couple of pics that may help.
    Thanks for the solution offered, but the problem now is more that the red is dominating (blue issue is still there but is not as severe as it was). I cannot post more than one photo, so hopefully you can see what I mean from the photo I posted. The read also appears on black clothing and hair in the picture, not just in the black space at the top and bottom of a non-HD picture. Thanks for any advice you can offer!
  • 4,889 Answers
May be a voltage band adjustment might do the trick for you? Was reading this article yesterday and found it very helpful for fixing a set with a similar issue. Dont worry about the sony.. This is a generic problem
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Oct 05, 2008
  • 1,800 Answers
Hi
i might be able to help u but i need u to follow me:
1/i need u to take that TV Apart
2/locate the motherborad
3/locate the convergence tube on the motherboard exactly the Blue one there is three ones on parallel
4/purchase the propper tube from this link www.partstore.com
best regards
    President:
  • 2,712 Answers
I think you may have an issue with the convergence chips which will need replacing. Replace BOTH chips at the same time. The IC's you are looking for are STK392-110.
You could always try a hard reset first - Unplug the power and cabling, wait about 2 hours and redo cabling and plug back into power source. Should the issue still occur, try the hitting the TV gently but firmly along the sides. If the distortion disappears, then that could indicate a cold solder or solder fractures on the board. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to fix it for you.
REMEMBER, there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
  • Swilin Sampson
    Swilin Sampson Oct 05, 2008
    If you would like to attempt a DIY, I suggest getting a service manual first. You can get it here:
    http://servicemanuals.vstore.ca/
    They also have spares and provide free online assistance while you attempt the DIY job..
    Hope that helps!
    Please don’t forget to rate or "Accept" the solution if it
    helped you in any way, or leads you to a fix.
    Thank you for using FixYa!
    IrishDruid
  • Swilin Sampson
    Turn down the red screen adjustment just a bit and see if this helps. Also try to keep the TV as far away from any source of magnetic interference as well.
    If the lines are horizontal, then it would be the vertical deflection driver that could be the source of the issue.
    Since it is highly likely you do have a loose connection or cold solder joint(s) you should do this:
    Open up the back cover so you can get into the main boards. Using a
    long wooden stick as a probe and a mirror out front so you can see what
    is going on with the picture, gently probe around until you find the
    hot spot. That will help you isolate where the problem is on the
    board(s).
    In my honest opinion, I think you should get a qualified repairman to take a look at this..
    Cheers!
    IrishDruid
    Master:
  • 479 Answers
Its the problem in the convergence STK ICS.get it replaced.
  • 1 more comment
  • tech gurus Oct 05, 2008
    there are three such STKICS replace all the three .
    and on the board there is a capacitor which is supporting the sound is at the end of its life so also get it replaced and soldered new capacitor.this is not a major problem.very common not very costly to get it repaired.
    for any further queries keep updated.
    thanks.
I took my Samsung HLN507W apart to replace the color wheel fan... is there a schematic somewhere in the TV or online so I can now put it back together?
You Tube have video by somebody take out the old colors wheel and steps by steps and a replacement of a new colors wheel put into the DLP tv.
May 08, 2011 | Samsung HLN507 50" Rear Projection...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. ...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. It always does the same thing: comes on for 1 minute, then powers down - there is no wait time in between unplugging and powering on. All fans seem to work and I cleaned the dust out of it. Help.
Nov 04, 2010 | Samsung HLN507 50" Rear Projection...
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
Directions
This will be hard to explain, but please bear with me. The 1994 unit I have is on ebay right now...I would imagine newer models are similar. http://cgi.ebay.com/Fisher-Price-Perfect-Support-Baby-Carrier-Gently-Used_W0QQitemZ290040314299QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116 The baby seat portion has one color clips, while the adult portion has a different color clips. Mine are white, and turquoise. The baby part has two 'buttons' near the **** area. Depending which one is snapped into the V shape notch on the adult part, the baby either faces toward the adult, or outward. The adult harness makes an X on your back, with a U shape in the front. The wider band part goes around the adults waist. On the baby seat part,the white clips go around the baby's tummy, similar to putting on a diaper. The turquoise clips on the baby part clip to the turqouise clips on the adults front shoulder area. Each strap is then adjustable for correct length. Hope this helps. I got mine at a garage sale, too, and it took awhile to figure out.
Nov 30, 2008 | Fisher Price Deluxe Perfect Support Baby...
COLOR WHEEL
you can check the settings on the manual of your tv or the configuration of the menu in the front panel.
Sep 08, 2008 | Samsung HLN567W 56" Rear Projection HDTV
Samsung HLN507W freezes with black and white specks
I had the same problem. It ended up being the DMD board, which is the mirror engine. cost about $1000 to fix. Better off buying a new tv.
Mar 23, 2008 | Televison & Video
BP9600674A
The jumper that you need to remove is a small usually black block of plastic approx 1/4" in across and 1/8" thick located near the center of the shiny silver colored apparatus into which the color wheel is plugged. Mine had a label that read FDB Bearing Color Wheel, BP67-00099A and two illustrations indicating open and shorted conditions. The label was just over the jumper. I pulled it out with needle nose pliers and the problem was solved. GndLoop
Mar 18, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
