Question about Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN will not collate
I have XP OS with a USB connection and two-sided printing. I have tried changing the collation setting to get this printer to collate. Strangely, when I print a single copy the pages come out face down in order. When i tell it to collate, the printer not only prints the number of two-sided printed pages but also prints 1/2, 3/4, 5/6, 7/8 pages correctly but the come out of the printer face up with page 1 up & 2 down, page 3 up and 4 down a so one. I did read that there was so bios changes some time back but I didn't save the page at the time. Any ideas?
Thanks, Ben debenllc.com
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Posted on Nov 26, 2008
I have a MFC7860DW, How do I set it to collate copies?
You can download the manual from here: Reference page 24: "Collate With the Collate check box selected, one complete copy of your document will be printed and then repeated for the number of copies you selected. If the Collate check box is not selected, then each page will be printed for all the copies selected before the next page of the document is printed."
Mar 02, 2015 | Brother MFC-7860DW Compact Wireless...
We have a Phaser 7300N that will intermittently run jobs without fusing. as you can imagine this makes one heck of a mess. we had this problem once before so we replaced the fuser, that only worked for a...
These are 2 different problems. The fusing issue is that the fuser roller is controlled by the "ATC Anvil calibration". This requires Transparencies (PN 42527801) to be run through the Manual feeder. You may need a technician for that, or buy a manual
The "reseat message" is probably a warping "top cover inner frame" 116-1548-00. You might need to replace that whole top.
Whit
Item, Inc.
May 24, 2010 | Xerox Phaser 7300DN Laser Printer
Collate copies
The control to collate printing is in the driver. If your machine is equipped with an output tray that will offset sort the sets then they will be staggered otherwise they will be in one stack.
This machine does not collate while copying. Dah...shame on Xerox!
Jan 06, 2010 | Xerox DocuColor 12 Printer
Xerox 6115 mfp has please wait on screen and has
General Troubleshooting
Product Will Not Turn On
Cannot Print the Configuration Page
Probable Causes Solutions
The power cord is not correctly plugged into the
outlet.
Turn off the product, confirm that the power
cord is correctly plugged into the outlet, and
then turn on the product.
Something is wrong with the outlet connected to the
product.
Plug another electrical appliance into the
outlet and see whether it operates properly.
The power switch is not correctly turned on (I
position).
Turn the power switch off (O position), then
turn it back to the on (I position).
The product is connected to an outlet with a voltage
or frequency that does not match the product
specifications.
Use a power source with the specifications
listed in Electrical Safety on page 1-2.
The tray is empty. Check that at least Tray 1 is loaded with
media, in place, and secure.
The product’s covers aren’t closed securely. Make sure the covers are closed securely.
Close all covers gently to avoid jarring the
product.
There is a paper jam. Clear the paper jam.
Driver Problems
With Pages/Sheet on Multiple Copies, the Output Is Incorrect
Booklet Left and Right Binding Output Is Incorrect
Did you set the correct date and time? Ensure you have set the correct Date and
Time on the control panel, through
CentreWare IS or the MCC.
The backup battery has reached the end of its
service life.
Replace the backup battery.
Media or settings are not correct. Make sure the duplex unit is installed and
enabled in the product driver.
Make sure that you are using correct media.
See Supported Paper and Media on page 6-2.
Do not duplex custom-sized media, envelopes,
labels, postcards, thick stock, or
transparencies.
Make sure that you have not mixed media
types in Tray 1.
In the product driver choose "Print on Both
Sides".
Both the driver and the application have been set to
Collate.
For Pages/Sheet on multiple copies, choose
Collate only in the driver’s Basic tab. Do not
set collation in the application.
Collate.
For Booklet Left Binding and Booklet Right
Binding, choose Collate only in the product
driver’s Basic tab.
Do not set collation in the application.
Status Messages
Message Definition Solutions
CANCELLING JOB The job is being cancelled. No action needed.
*ENERGY SAVE* The machine is in Energy Saver
mode to reduce power
consumption during periods of
inactivity.
*PLEASE WAIT!* After replacing a toner cartridge,
or after rebooting your machine
after environmental changes,
your machine automatically
pauses to do an Auto-Image
Density Control (AIDC) cycle.
This process is provided to make
reliable machine operation with
optimum output quality possible.
The machine is warming up.
Aug 19, 2009 | Xerox Office Equipment & Supplies
Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
May 26, 2009 | Brother HL 1440 Laser Printer
Collate issue
Have you tried switching the type of driver. From PS to PCL ?
I will look up more in the morning and get back with you.
Jan 29, 2008 | Xerox Phaser 8500/DN Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
485 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
