Question about Frigidaire FAA065M7A Air Conditioner
Window unit do they make adapters for windows that are bigger than 36 inch when doing installation?
    Scholar:
  • 121 Answers
The adapters that come with the unit are sized according to the size of the unit so that when they are fully retracted they do not ove lap the unit. There are different size units depending on how many btu's are required for cooling. If the window is larger than the wing span of the unit you will have to prefab the difference.
Posted on Sep 27, 2008
How many inches is there in 3 feet?
36 Inches. Each foot is 12 inches, multiplied by 3 equals 36 inches. Also referred to as one yard.
Aug 28, 2014 | Adobe Photoshop CS6 Extended - Windows
Frigidaire FAC107S1A leaking water thru the inside of the house
Hello, first make sure the unit is tilted back in the window about a 1/4 inch. Also, check the drain on unit, sometimes they can clog and prevent condensate from draining.
Jul 31, 2012 | Frigidaire FAC126P1 wall/window Air...
No 3d3 drivers with hardwere acceleration fund
Well, if you're running Windows, and you have a videocard bigger than 4 square inches, you need to install the drivers for that card, and then go to http://www.gamesforwindows.com/en-CA/directx/ and install DirectX. After that, try the program again; if it won't run, maybe you actually do have a VESA videocard with no 3D acceleration to speak of, and therefore can't reasonably run the 3D program or game you're trying to run. Not without dropping $200 on a videocard.
If you're not running Windows or a reasonable WINE or VMware virtualization of such a system within Linux, you seem to need a different build of the program.
Mar 11, 2011 | Computers & Internet
I installed 256mb video card to my pc but as it runs window xp after boot screen it goes blank.what should i do?
The Frequency of the new card is heigher than what your Monitor can carry. Use a bigger screen Monitor say 19 inch or 21 inch monitor it should be able to carry the card. Reset the frequency to somthing low and connect back your monitor.
Sep 23, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
What are the measurement on kenmore airconditioner model #580.72056
INSTALLATION REQUIREMENTS
Your air conditioner will install into standard double
hung windows with actual clear opening widths of
22 to 36 inches (558mm to 914mm) (FIG. 1).
Lower sash must open sufficiently to allow a clear
vertical opening of 14 inches (356mm). Side louvers
and the rear of the air conditioner must have clear
air space to allow enough airflow through the
condenser for heat removal. The rear of the unit
must be outdoors, not inside a building or garage.
•_22" to 36" --
14"rain
Intedor wall
Sash
Winddow
"-_,_- Offset
-- Sill
-- Exterior
"" .... " FIG.
This came from sears.com
really is no dimensions for the unit itself just the opening that is needed for it to fit
Jun 21, 2009 | Kenmore 72056 Air Conditioner
Poor gas flow to GE cooktop
Try a bigger inlet pipe sounds like pipe too small for load .
Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
I reistalled Windows XP and sincew doing so I have lost my wireless connection
This is probably because your wireless adapter or network driver was uninstalled with the installation of Windows XP. I suggest looking up your motherboard and finding its network driver. If your wireless adapter is a card, then look up that driver as well.
Oct 23, 2008 | Medion Computers & Internet
Window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
May 19, 2008 | Frigidaire FAC124 wall/Window Air...
Windows Vista won't boot
Windows vista is not included in product min OS requirements technical details. That may be the problem.
Product Features
  • HP DC195A Serial/Parallel Multi I/O PCI Card General Features: Serial/Parallel adapter PCI interface
  • Easy to install Fast transfer rate (430 Kbps) Connectors: One (1) Serial port (9-pin D-Sub DB-9)
  • One (1) Parallel port (25-pin D-Sub DB-25) Regulatory Approvals: FCC CE
Technical Details
  • Model: DC195A
  • Item Package Quantity: 1
  • Hardware Platform: PC
  • networking_feature: Parallel/serial adapter
  • form_factor: Plug-in card
  • Network Interface Description: PCI
  • Connectivity Technology: Wired
  • Data Link Protocol: Parallel, RS-232
  • Minimum system requirements: Microsoft Windows NT, Microsoft Windows XP Home Edition, Microsoft Windows 2000 / XP Professional
  • Depth: 4.7 inches
  • Height: 3.5 inches
Jan 22, 2008 | HP (DC195A) Serial Adapter
Super G 802.11g/b
ok look in device manager down the list to your wireless card and see if it is listed, if so check that there is not a red cross on it, if so right click and select enable. if a yellow exclamation mark driver not recognised with card. If it is listed and you are unable to enable it restart the pc and press F2 or DEL to enter your bios and on the peripherals menu, see if the wireless controller(if it is built in card) is enabled. If non of the above works, then the code 10 would normally be refering to a faulty peice of hardware.
Mar 18, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
Frigidaire FAA065M7A Air Conditioner Logo
77 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
