Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
I changing the belt
Any ideas how i change the belt on my dyson with brush control
  • Anonymous Jan 14, 2009
    can you show me how to change the belt for dc14
  • 372 Answers
Not sure why you claim clutch belts cant be changed because they can.
The DC04 DC07 DC14 all use the same clutch unit if you cant get the belts from your local vac repair shop look on Ebay they are on there.
The special tools are torx screwdrivers & if replacing both belts you will require circlip pliers.
How to replace both belts in manual form can be found here http://dysonmanuals.llc.nu/index.htm
Posted on Oct 09, 2008
  • 102 Answers
It is possible to change the clutch belt(s). However it is much easier as a diy person to change the complete clutch. If you goto you tube there are videos showing you how to do both
Posted on Oct 18, 2013
  • 37 Answers
You cannot just change the belt on this model. you have to replace the clutch assy. this is a process that takes special tools and you may want to take it to your local vac tech. this repair is $69.99 where i work.
Posted on Sep 28, 2008
  • dayle53 Feb 10, 2011
    Not true! I'm a woman and did it myself in 1/2 hour. Cost of belts $7! Read solution 4!!!
You don't even have to remove the clutch assembly. Remove the bearing end on the brush and slide the belt over the end. Use a screw driver to strech the belt over the new brush.
Posted on Jan 05, 2009
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
How to change belt on Dyson dc33
Hi William, it's Jack at Dyson.
DC33 doesn't use a traditional, user-replaceable belt. Instead, the two belts are part of the brush control mechanism, which allows you to shut off the brush bar to clean hard floors and delicate rugs. These belts are engineered to last the lifetime of the machine in normal use.
If your DC33's brush bar isn't currently rotating, please follow each of the steps shown in our online Support guide, to rule out any simple issues: http://www.dyson.com/support/dc33/dc33-multifloor/using-my-dyson-list/flo-dc07-gen-how-to-remove-a-blockage/redirect-to-removing-debris-from-the-brushbar-dc33/removing-debris-from-the-brushbar-dc33
It's also important to make sure your DC33's brush control is set to carpets rather than hard floors:
If you still need help with your machine after trying these simple checks, you're welcome to get in touch directly. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Apr 30, 2015 | Dyson DC33 Multi-Floor Upright Vacuum...
How to change belt in dyson upright model dc07
Hi there, it's Jack at Dyson.
There are two versions of DC07 - some include a brush bar which rotates all the time when the vacuum is running. And some include a brush control clutch mechanism which allows you to turn off the brush bar for hard floor cleaning. If your machine has the brush control, you'll see the dial on the front of the cleaner head.
If you have a DC07 without the brush control feature, you can replace the belt as shown in our online Support guide: http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if you have a DC07 with the brush control feature, the clutch mechanism uses belts engineered to last the lifetime of the machine in normal use. These are not designed to be replaced by the user, and we would advise against attempting to change these as damage may be caused to your machine.
For further advice on having your machine repaired, or to order replacement belts for a DC07 without brush control, please contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 30, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where is the brush belt on a dyson 07 upright vacuum?
The type of belt mechanism will depend on which model of DC07 you own. If you have a DC07 machine without the brush control feature, the user-replaceable belt is located within the cleaner head:
However, if your DC07 includes the brush control feature (you should see the Carpet/Hard floor dial on the cleaner head), your machine will use a clutch mechanism with belts engineered to last for the lifetime of the machine in normal use.
If you have a DC07 with brush control and would like some help with it, please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dco7
you need to lie the dyson out on the floor/table and you will see some screws underneath holding the rotating brush in place, remove these with a torx bit and you will see how it lifts up to allow the belt to be replaced, just keep track of how things sit to make it easier to put back together
Mar 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
The belt on my Dyson DC14 will not turn. How much will you charge to change the belt.
Sorry to hear you're experiencing a problem with your Dyson. If your DC14 doesn't have a Brush Control option, you should be able to replace the belt yourself - you can find out how to do this here:
http://www.dyson.co.uk/support/help.asp?article=635&product=DC14-SY-STD
If your DC14 has a Brush Control, try checking for and removing anything blocking the brush bar. You can find out how to do this here:
http://www.dyson.co.uk/support/help.asp?article=668&product=DC14-ANIMAL
If you require further assistance, please get in touch with us free, on 08002980298, or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Feb 26, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a dyson model seven all floor. It is making a terrible grinding noise when the carpet knob is engaged. Could something have gotten sucked up into the belt compartment, off the brush belt? Any...
That is most likely what happened. You may want to open up the bottom where the floor brush is and check the condition of the belt and as to whether or not something is caught in the belt or beater brush. The owner's manual should provide directions on changing the belt. While you are changing the belt, give the beater brush a good cleaning and add some WD40 to the ends of the brush where the plastic holders are located.
If you find my solution to be of help, I would appreciate a Thumbs Up rating from you.
Paul
Oct 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to change brush belt on dco7 dyson
This depends on whether your DC07 has a brush control clutch or not. For excellent illustrated guidance go to www.dysonmedic.com and click on DC07. For belt change on a model without clutch click on "belt and brushroll". It's simple! For models with a clutch, click on "clutch replacement". It's not so simple!
Feb 16, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Revolving brush stopped after I got a sock snagged in it.
If the Dyson model has a brush bar control roller at the left hand side of the top hood then it won't be able to be repaired unless its by a Dyson call out or someone who repairs Dyson models with brush control protection.
If the model doesn't have a brush control dial then you will have to change the drive belt:
Easy to do if you flip the machine over with the beater bar looking upwards. Locate the three/two screw heads and undo with a coin. When the roller section is revealed by taking off the floor head you should replace the belt with a new one and be careful putting the beater bar in the right way on both ends. The belt will be tight brand new so expect some tension in it.
If this works for you please rate Fixya! Thanks.
Mar 28, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
890 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
