Question about Belkin Computers & Internet
I dont have the c d for my wirless router and i want to update my main computer.i am affraid if i do that without the c d then i wont be able to use my wirless laptop.is there a download i can get?
Hi There ! When you say you want to update your main computer can you explain in more detail please
Posted on Sep 27, 2008
  • davhar Sep 27, 2008
    Hi The link will allow you to download a generic setup guide for the belking routers.
    After you change the PC simply plug the ethernet cable back in to the router and it will pick up a connection to the internet.
    If you want to use wireless, when you power up the pc it should see the wireless network and you simply need to connect and input the security information if you have set this up.
    If you change the PC the router will not be affected.
    Hope this helps
I dont have any cd instalation how can i do for have a softwear
IF U R USING ETHERNET CABLE TO CONNECT ROUTER THEN NO NEED OF CD.OTHERWISE USB ........WIRLESS THEN U NEED CD.......GO TO DLINK.COM
Mar 20, 2010 | D-Link DSL-G604T Wireless Router
Router operation without Internet connection.
Yes i can help you with this
You dont need internet connection
Feb 12, 2008 | Linksys Wireless-G WRT54G Router
Acer router wireless problems
I assume you mean D-Link Router Acer Computer?
If you did then most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you discribe
Feb 16, 2010 | Acer D-Link 2.4GHz Wireless Router 802.11b...
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Linksys wirless G 2.4 broad band router download driver
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 10, 2009 | Linksys Wireless-G WRT54G Router
I cant get wirless xbox live
The 1st question I have is, are you using the official Microsoft wireless adapter (sold seperatly) manufactured by Microsoft? That is the first solution to this issue. If so you must go into your router settings using the home router IP address usually listed on the router unit and setup the router manually to see the microsoft wireless adapter (sold seperatly), try typing this ip address into your browser address line (192.168.1.1) this is usually a generic router IP address to access your router. Your 360 should have a MAC address listed when in the settings and that should be seen by the router as well. Also check your firewall settings to make sure that it allows wireless transmissions. ( My computer usually has to be running for it to see wired & wireless devices properly). I also prefer just running a wired network for connectivity issues with wireless, such as other electronic interferrence from cordless phones & microwaves as I sometimes get with my nintendo Wii.
PAeasop
Apr 20, 2008 | Microsoft Xbox 360 Console
Wirless router and apple macbook
Did the router assign an IP to your MacBook? Do you use security/encryption on your MacBook?
Mar 31, 2008 | Computers & Internet
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
I want fast help..how to get connection between linksys router and aztech modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
