Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Kichtenaid DISHWASHER KUDS01
IT WILL NOT START. THE CLEAN LIGHT IS FLASHING. HAD PROBLEM BEFORE AND HAD TO PAY A REPAIRMAN $100 TO RESET THIS. HOW DO I RESET THIS.
  • gsacspine Nov 12, 2008
    We have a Kitchen Aid KUDI01IL dishwasher. It will not start and the clean light is flashing. Tried the cancel button, but clean light still flashes. We do not have the sanirinse and heat dry buttons, so can't exactly do the suggested fix. Tried it with buttons we do have with no success. Thanks for any help you can give.
  • Anonymous Nov 20, 2008
    I have the same model with the same problem. Is there a water inlet filter that could be clogged?
    Problem Solver:
  • 9 Answers
On Whirlpool and Kitchenaids the flashing clean light means that there is a problem with the heating element circuit and probably the element itself. You can try to reset the machine by clicking the sanirinse and heat dry buttons back and forth a couple of times. All of the lights will come on and it will reset itself. If the machine keeps going to the flashing clean light then replace the heating element and reset the machine again.
Posted on Oct 11, 2008
    Novelist:
  • 171 Answers
Hi recyclr,
I'm Harvey the Master Plumber.
Your problem is: IT WILL NOT START. THE CLEAN LIGHT IS FLASHING. HAD PROBLEM BEFORE AND HAD TO PAY A REPAIRMAN $100 TO RESET THIS. HOW DO YOU RESET THIS.
Turn the power off at the circuit breaker for ten minutes. Sounds like this is only a temporary fix. Something else is going on here. If the problem persists look to the control board. This part usually cost over $ 100 so if the d/w is over six years old I'd compare the costs of repair verses replacement. A new one can be had for under $ 500.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
The Clean light is flashing and unit will not start. Manual says it is a heating circuit malfunction call a repairman. Heating element tests good, wiring appears fine. What is needed?
Hi, the reason why you are getting the flashing light is because the dishwasher failed to detect a 4 degrees rise in the water temp during the first 8 minutes of the cycle. Some reasons for this is a faulty heater, door switch,(heater runs through the nuetral side of the door switch), lack of water, d/w not filling correctly, should be just below heating element. Clear the fault by pressing following order. .
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Jun 13, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
My kitchen aid whisper quiet dishwasher will not start and the clean button is flashing
The flashing clean light is an indication that the water did not heat properly. Follow the link below to some instructions I put together that will show you how to reset the control so you can use the dishwasher again and what may have caused the error. Let me know if this is helpful.
Clean Light Flashing
May 22, 2010 | Dishwashers
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Kitchenaid dishwasher model kuds01
you have a water heating problem. there is a tech sheet taped to the inside of the toe plate
Dec 31, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Whirlpool Dishwasher power surge results in flashing clean button
I'm not sure what the sequence would be on your particular model as Whirlpool dishwashers can differ in operaiton. However, if you remove the lower kick panel under the dishwasher door, there should be a tech sheet either directly behind the panel, or tucked inside the door. The tech sheet will list all troubleshooting tips and any fault codes that the owner/operator's manual does not list. This is the SAME sheet the repairman will reference when they come to your home on a service call. Please let me know if you still require assistance. I hope this helps you.
Oct 22, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
824 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
