Question about RCA F32649 32" TV
RCA tv model F32649 white horizontal lines
It started with white horizontal lines across the top of the tv and it would do this for a couple of minuets every now an again for about 3 weeks. Then it started to look as though it was shrinking the top half of the picture to the center of the screen. The bottom of the picture appears normal with a scrunched picture in the middle and the top half of the screen was black. It was doing this for about a week and then it would fix it's self an all would be well for a while. Now it is scrunched all of the time. It is like this for all channels and the sound is not affected at all. Thank you for any help you can provide.
  • 252 Answers
The problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Posted on Oct 31, 2008
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
Two horizontal lines going across the screen
hi i have the same tv mine just started doing this last week were you able to fix the problem if so wht was it
Dec 02, 2012 | Samsung PN50B550T2FXZA PN50B550 50 Plasma...
Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Apr 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Insignia 32" TV Thin line across screen 1-2" from top
The original white line problem was caused by improper adjustment of the vertical size for which there is an internal adjustment. The current problem could come from two different sources, one an adjustment again, the other from a capacitor that is losing capacitance and gaining losses; = sick.
If you are fortunate enough to have a surviving TV repair in your area, none of these problems is expensive to find or correct.
Don't be surprised to find the only TV shop operating out of a messy garage since those of us doing this kind of service are dying off and the price one can charge for labor has shrunken to the point that a real business address is too expensive to have.
Jan 03, 2009 | Televison & Video
Horizontal lines across the top 3 inches of picture
what line started? from Left to right? or from top to bottom?
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
White horizontal lines at top of picture
Yes, definitely worth fixing. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor (no more than USD4.00 in price) usually gets it working perfectly again. If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Jan 17, 2008 | Toshiba MD24FP1 24 in. TV/DVD Combo
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Mitsubishi Projection TV. Works for a couple of hours and then the picture shuts off
Very often older Mits CRT's develope a slow leak of coolant
onto one of the circuit boards....various problems arise,depends
on where the drip lands....even a good tech can miss the drip
evidence.....I have pulled the chassis to the shop only to find
"wet" area under well-lit conditions.................T.
Nov 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
RCA F32649 32" TV Logo
261 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
