Yahoo messenger 9.0
I have had to reinstall Yahoo Messenger 9.0. When I click on the short cut to bring it up to sign in....I get a Windows error message telling me it has stopped working....... Options are check online for a fix and close program or close program. Is there a fix for this? I am running Vista
Thank you.
  • 3 Answers
Hello gud day to you..im don aXer..im also a vista user and the time i've encoumtered the same problem i found out that it was an error came up with ur installatuion over the ineret..it was caused by intermitent internt connection therefore uninstall the program yahoo messenger thru add/remove program then reinstall it..if still havnt solve the problem maybe the software itself is the problem...download a new copy of the installer over the internet...pls confirm if u already solved the problem..tanx
Posted on Sep 27, 2008
Yahoo messenger erroe 81003002
This error code indicates a sign in problem with Yahoo messenger. Try some of the following tips to resolve the issue.
-Make sure you are entering in the correct log in credentials. When the error pops up, there is a "Sign in Problem" button you can click on for further assistance.
-Make sure your computer is not infected by a virus. This has been known to cause this error.
-On Windows, Press Ctrl + Alt + Delete and bring up task manager. In task manager, go to the processes tab, and in the process list look for something like yahoomessenger.exe. Highlight and click end process. Now run yahoo messenger and try to log in.
If the above does not work, uninstall yahoo messenger and reinstall.
Regards,
G33k
May 15, 2011 | Yahoo Messenger
Cannot open yahoo messenger, yet i am signed in
Try using the below website for signing in:
http://webmessenger.yahoo.com/
If that work than the issue is with the Messenger application reinstall the messenger.
Sep 05, 2010 | Yahoo Messenger
81003002 yahoo messenger error
Here’s what you need to do in case you encountered Yahoo messenger error 81003002:
  • Double check your Yahoo ID and password. If at several times of sign in attemps but you still get the same error, restart you PC and if you are connected to a modem or router, do the same.
If you are sure that no virus has actually penetrated the system, there is no need to run a system scan.
  • While some blogs advice reinstallation of the software (of the same verision, i.e. v9) and some may even advice removal of v.9 and installation on an older Yahoo messenger version like Yahoo Messenger 8, do not waste your time as I have already done that. The older version of the IM software no longer works.
Again, if you have had error 81003002 while attempting to sign in to Yahoo, open Windows Task Manager (by pressingCLT+ALT+DEL), select Processes and find YahooMessenger.exe and click End Process. Try to do this several times but if it does not work, then try to reinstall the software. Doing this step does not guarantee that you will be able to sign in but its worth the try. The surprising thing is that when it happened to me, I removed Yahoo Messenger v9 on one of the PCs within my nextwork, the next day when my sister checked it out, she was able to sign in. It just simply fixed itself overtime. Huh?! It’s fascinating why did it happen? Could it be that our IP has been blocked by Yahoo for the entire day and restored it afterward? It’s not a virus as I’m 100% sure. It could be a bug though but I’m not certain what caused it so what I did was reinstall the instant messenger again and I was able to sign in to Yahoo messenger finally.
This is what happened and it’s something that I don’t have any technical reason to offer but I suspect that it was really a bug. Have you experienced the same scenario? What did you do?
FYI, if you are in need of using the application but was caught in a situation similar to the one discussed, you can try signing in to these alternative link or sites to get Yahoo! Messenger access.
Mar 28, 2010 | Yahoo Messenger
I can't install yahoo messenger 9 version. i get an error message when trying to install yahoo messenger 9. incorrect command line parameters.
We need to uninstoll it then reinstall it.
1.- clck START
2.- click SETTINGS
3.- click CONTROL PANEL
4.- select ADD IREMOVE
5.- LOOK FOR MESSENGER 9
6.- SELECT REMOVE
it may ask you if you sure say YES
when is all gone.
RESTART your computer and go to msn.com try to install it again be patient don't open any windows or games it will take few min but will be better.
Your rating is very important to me...
Was this helpful?
May 28, 2009 | Yahoo Messenger
Problem signing into Yahoo Messenger.
uninstall yahoo messenger completely and download a fresh one, re install fully, if still has errors, contact ym http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
Nov 20, 2008 | Yahoo Messenger
Download Yahoo Messenger 9
Make sure messenger is off, then go to regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
or
It's either one of the two:
- Yahoo! servers are down for maintenance, the only fix would be to wait.
- Your connection preferences are wrong:
Messenger tab just above where you sign in and then click the Connection Preference option
Oct 21, 2008 | Yahoo Messenger
Problems with yahoo messenger 9
make sure you update all to the latest drivers via windows update
or
Oct 20, 2008 | Yahoo Messenger
Signing in problem with messenger: 81003005
i have a problem error 81003005 how can i remove that error ?
SOLUTION
Make sure messenger is off, then go to start>run> regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
Sep 28, 2008 | Yahoo Messenger
Computers & Internet Logo
66 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
