Question about RIM BlackBerry Pearl 8100
Camera Won't Start!
I have the Curve 8330. When I try to start the camera, it comes up with a screen that says, "Could not start the camera. Close other applications and try opening again." I have turned off the device, I have removed the battery. I'm not 100% sure on what it means by "close other applications" but could someone please help!
    Sniper:
  • 84 Answers
First, try a hard reset on the device: remove the battery from the BlackBerry while it is still powered on. Leave it out for 30 seconds, then reinsert.
If that doesn't work, then you may need to add a memory card (micro SD/SDHC) to the device.
Posted on Oct 05, 2008
BlackBerry® Curve™ 8330 Cellular Phone: hello! my bb curve 8330 won't power on, it is givi...
Might be that the battery is dead.
let it charge for hours without trying to power it.
after that, unplug and press the start button and let it works a few minute. it might take a while.
good luck
May 16, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Camera phone won't load. "close all apps and then restart." Tired soft reset, hard reset and update.
Make backup on your PC.
Wipe the BB, options - Security -General Settings - drop down menu - WIPE
Restore the backup from your PC.
This will solve camera corruption.
Nov 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
The flash on my blackberry 8330 wont work.
First, ensure that the flash is on in the camera settings, which are accessed from the camera screen by pressing the blackberry key and going down to Options. The first setting is default flash settings, and your options are on, off, and automatic. If it is on, you most likely have a damaged flash or a loose cable inside of the phone.
Nov 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry curve 8330 camara problems only see a purple or sometimes green screen...& not able to take pictures...
It occurs when Camera application gets corrupted.
Kindly install the Blackberry device software using Desktop Manager application and then try.
To Install Blackberry Device Software
1.Connect the BlackBerry smartphone to the computer and open
BlackBerry Desktop Manager application
2. Double-click Application Loader.
3. Click Next to start the installation process.
4. Type your BlackBerry smartphone password, if prompted, and click
OK.
5. Select the check boxes next to the names of the applications you want
to load, and then click Next
6. Click Advanced, and then select the check boxes beside Erase all
application data and Erase all currently installed applications
7. Click Next.
8. Click Next > Finish.
9. When the process is completed, the message, The loading operation
was successful will appear. Click Close to return to BlackBerry
Desktop Manager.
Please contact your Service Providor of SIM card for further assistance on the same.
Nov 09, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Could not start the camera. Close other applications and try opening the camera again
Very gently take the back off of the Blackberry, slightly push in on the camera itself, reboot and the camera should work.
I found out the hard way selling my phone on eBay only to have it returned because the camera didn't work. It's a hardware issue and not a software issue.
If it's still under warranty, try and get a new phone, otherwise --problem solved.
Feb 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Accidentally deleted camera icon
I don't think you can actually "delete" the icon for the camera, at least not using the handset. You probably only "hid" it. Try hitting the option button and then select "show all" you should then see the camera icon but slightly grayed out/transparent. go to it and then uncheck the hide option. You can then de-select show all and you should be good to go. If this does not fix it and you did actually delete the camera function, let me know so I can walk you through that detailed process.
Jan 21, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
Blackberry Curve 8300 Camera Problems
After reading many posts, I removed the back and and pulled out the battery, then removed the memory card and blew air all over it, put it back together in reverse order, and works like new.
Oct 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
Camera wont start!
If these two options haven't worked, then the final thing to do is actually delete the entire operating system and reload it from scratch. There is a program called JL_Cmder that allows you to completely erase the operating system and data and programs. Check out the two links below:
Wipe operating system with JL_Cmder: http://blackberryfaq.com/index.php/How_do_I_wipe_the_BlackBerry_using_Jl_Cmder%3F
Install new BlackBerry operating system: http://crackberry.com/blackberry-101-how-install-or-upgrade-new-rim-operating-system-os
Sep 29, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry  Pearl  8100 Logo
204 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
