Question about Sony KP-51WS500 51" Rear Projection Television
Screen turns blue then shuts off, front led flashes 8 times
  • 2 more comments
  • rbarkin Jan 18, 2009
    I have the same problem with a 51 inch sony rear projection about 6 years ole .. is that $$$ to fix or should I throw my set out and get another
  • bbruton Feb 09, 2009
    My Sony KP51WS500 comes on just fine -- looks good -- then over about 30 seconds fades to total blue -- I turn off and wait 5 sec and turn on and it is all good then fades to blue again
  • CDoyle1013 Feb 15, 2009
    Same problem. Turn on, screens turns blue and shuts off. Had the tv for about 2 and a half years and did this...dumped a grand into it and SONY recommended repairman cannot fix...states that I need three new tubes of some sort. (My RCA lasted 15 years - how could a SONY last 2 and a half? -especially for the money paid) Sorry, Sony - no more Sony of my owny. I am done with SONY.
  • loriprice02 Feb 21, 2009
    Tried repluging into different outlet. Still faded to blue then turned off????? any other suggestions
    Genius:
  • 2,920 Answers
Youre losing your power supply
Posted on Nov 04, 2008
I have a 2000 Sony projection tv. When I turn it on it has a blue screen then it shuts off in around 5 seconds. The light on front keeps flashing 8 times in a row. Any ideas?
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
Consistently finding that as an answer. I would assume that is the part that is broken. The 8 blinks is an error code which points to this part being faulty.
Oct 24, 2012 | Televison & Video
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
My Sony TV shuts down after you get a bright flash of light from the screen. After it shuts down, the red LED light on the front flashes 8 times. What's the problem?
On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Mar 11, 2011 | Sony KP-51WS500 51" Rear Projection...
It appears something is wrong with the green tube. The picture comes on and then the green tube flashes and the TV shuts off and the LED blinks 8 times
This set has a history of bad picture tubes but there is an adjustment you can try to see if it will buy you some time to use the set further.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the GREEN will be in the middle.
7.) Once you locate the GREEN screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the Blue screen down until the set stays on and then very slowly turn it up until you see a slightly Blue screen with or without diagonal trace lines----turn it down slowly until the GREEN screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the screen down a few times to get it to stay on.
Regards, SD TECH
Apr 03, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Jul 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Kp-51hw40 problem
your blue tube is shorted unplug blue crt board see if set comes on and stays on!
Nov 07, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
116 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
