Question about Hitachi 50SBX70B 50" Rear Projection Television
TV lost power - Protect LED D912 blinking
My Hitachi 50SBX70B lost power within seconds of plugging in, all the green LED's lit for a flash then went out slowly. Only the Red LED (D912) labeled Protect LED is blinking. I checked pico fuse E994 and it's OK, also C701 seems to be OK since I don't see any burn marks.
Any help is appreciated.
Thanks,
Tim
  • 12 more comments
  • tim_2000 Sep 27, 2008
    There is a Red LED flashing (D912), none of the green LED's. Which capacitor(s) are you recommending to check?
    Thanks,
    Tim
    Isn't the power supply part of the main board? Is there any way I can check output of some test points, etc. to make sure?
    Thanks,
    Thanks for the pointer but I have to pay for the service manual and it's in Adobe.
    Still looking for some leads to fix it. Hopefully manual has tips for this problem.
    Tim
    This is very helpful.. I'll check as much as I can before I call TV repair service. I may need some more helps..
    Thanks,
    Tim
    Well, I followed the troubleshooting flowchart on pages 32-33 as you suggested and my problem seems to be on the (A) path. The voltage at pin 5 of I901 is not right (-42V instead of +10V to +16V). Then I proceeded to check the 5 components it suggested and pretty sure that R905/906 and D907 are OK, not 100% sure about Q901 and C907 (don't know how to check them on PWB). There is no burn mark on any of them..
    Any suggestions?
    Thanks,
    Tim
  • tim_2000 Sep 28, 2008
    Where can I get parts for this TV?
    Thanks,
    Tim
    All pico fuses are OK but there is no power after T901. There is 113V at E991. Any experience with this problem?
    Thanks,
    Tim
    I have background in electronic so I can read schematic and use multimeter but not so much on repair. What I want to do is to eliminate the obvious problem that I can service it myself. But if the problem is more than I can handle then I'll definitely call TV repair service. As I posted earlier, from Protection circiut block diagram, I have DC 113V at both end of pico fuse E991 but no DC on the other outputs.
    Thanks,
    Tim
    I don't understand how C707 get into the picture here? I think my problem is on the Power Protection circuit (block diagram page 40 in the service manual).
    Thanks,
    Tim
    Thanks for all the helps. I'll spend Sunday to play around and call repair service on Monday..
    Tim
  • tim_2000 Sep 29, 2008
    Because the power protection circuit shutdown a few seconds after power up, there is no power anywhere in the H circuitry. I'll have to call the repair service to come look at it.
    Thanks for the helps..
    Tim.
    Thanks all for your suggestions and helpful instructions. Don't be upset that I keep reposting this and have not accepted any solution. I'll take a route to call repair service for this one. I'll post the solution when the TV is fixed.
    Thanks again..
    Tim
    How can I disable protection?
    Thanks,
    Tim
  • tim_2000 Nov 06, 2008
    The problem is fixed by repair service. According to the repair description, it was cold soldered joints on main PCB.
    Thanks for your assistance.
    Tim
  • 171 Answers
Symptom: BLOWS E994
Cause: DEFECTIVE D604
Symptom: BLOWS I401 EVERY FEW WEEKS
Cause: DEFECTIVE C410
Symptom: DARK PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Cause: DEFECTIVE C724
Symptom: DIGITAL CONVERGENCE WON'T ADJUST
Cause: DEFECTIVE DCU
Symptom: E994 KEEPS BLOWING
Cause: DEFECTIVE C701
Symptom: INTERMITTENT COLOR ON ALL INPUTS
Cause: DEFECTIVE IY01
Symptom: INTERMITTENT REMOTE FUNCTIONS
Cause: DEFECTIVE IR HM01
Cause: DEFECTIVE D029
Symptom: INTERMITTENT VIDEO
Symptom: LOSS OF SYNC
Symptom: NO AUDIO
Cause: NEED TO RESET EEPROM I004
Symptom: NO CLOCK/SLOW CLOCK/CAN'T ADJUST CLOCK
Cause: DEFECTIVE D031,R0H8,Q018
Symptom: NO CONTROL OF BLUE COLOR
Cause: DEFECTIVE D511
Symptom: NO FRONT CONTROLS FUNCTIONS/REMOTE OK
Cause: DEFECTIVE DM04
Symptom: NO HOR SYNC
Cause: DEFECTIVE I008
Symptom: No Horizontal Sync. When PinP is called up, main picture may lock up for a 8 moment, then it goes back out of sync.
Cause: I008 defective (Sync Switch)
Symptom: NO LEFT CHANNEL
Cause: DEFECTIVE I401
Symptom: NO OSD
Cause: DEFECTIVE D716
Symptom: NO OSD
Cause: DEFECTIVE I102
Symptom: NO PICTURE
Symptom: NO POWER
Cause: DEFECTIVE I912
Symptom: NO REAR AUDIO
Cause: DEFECTIVE IS11
Symptom: NO REMOTE FUNCTIONE/FRONT CONTROLS OK
Symptom: NO REMOTE FUNCTIONS/FRONT CONTROLS OK
Cause: DEFECTIVE DM11
Symptom: NO SOUND
Symptom: NO TUNER AND ALL INPUTS
Cause: DEFECTIVE IYO1
Symptom: OSD LATCHUP
Cause: SEE PTV98-4B
Symptom: PICTURE PULLS
Cause: DEFECTIVE D702,D703,D704
Symptom: RANDOM CHARACTERS ON SCREEN
Symptom: REPLACED DCU/RECONVERGED/NO MAGIC FOCUS
Cause: DID NOT INITIALIZE SENSORS
Symptom: RK46 VERY HOT/STK'S HAVE BEEN REPLACED
Symptom: SHUTDOWN
Symptom: SHUTDOWN
Cause: DEFECTIVE I601
Symptom: SHUTDOWN
Cause: DEFECTIVE C715
Symptom: SHUTDOWN/OPEN E995,E996
Cause: DEFECTIVE T702
Symptom: SMEARED PICTURE
Symptom: SNAPS/BLOWS Q777
Cause: CRT ARCING
Symptom: WEAK COLOR
Symptom: WON'T HOLD CHANNEL MEMORY
Cause: DEFECTIVE EEPROM I004
Symptom: NO AUDIO
Cause: Q013
Symptom: SHUTDOWN
Cause: Q777,I901
Symptom: SHUTDOWN
Cause: E994,D724
Posted on Sep 29, 2008
    Master:
  • 726 Answers
Yes best idea is to call the guy to come see it its not worth the trouble on here to go though everything and replece some ansews are stupid as i can see also this problem is still visable to us unless some one is rated a fixya ok thanks for your time have a great day from chris07551
    Scholar:
  • 148 Answers
The timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
~KEEPS US UPDATED.
Posted on Sep 28, 2008
    Master:
  • 479 Answers
Calling a service technician is much advisable.as he will also detect the other problems that you can face further in your device and that will make the unit perfectly all right.
    Sergeant:
  • 208 Answers
I want you to check these......
Pico fuse E994 open?
The +120VDC indicator LED D940 was unlit?
you said that the "protect-mode" D912 was flashing....
Check whether the small blue 2KV scan disc cap hidden under the larger ones
had arced internally: C707 "102 / 2KV"C707.
Thanx for using fixya,
Waiting for your reply.....
Good luck.
  • Hitachi Master
  • 1,800 Answers
Try to replace the ignition board its the faulty in this casse cuz its not giving the signal to the whole borad to initiat the tv.
  • 2,071 Answers
The condition of your TV called power supply overcurrent shutdown. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up,only a red standby light. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating .I would probably also check the flyback circuit and flyback transformer although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.
Hope this may help you..
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Sep 29, 2008
    If you already replaced the right spare parts and your Plasma TV is okey , then the protection mode will be disabled...
    Regards,
    VOTIT
  • 10,594 Answers
If you don't have schematic of your Hitachi 50XBS70B, download it HERE by entering model number in search box. Next page will show you service manual files, download all 7 parts and extract with WinRAR software.
This will enable you to go through troubleshoot chart in service manual and locate and test defective parts.
Regards,
Posted on Sep 27, 2008
  • 4 more comments
  • Shahid Electronics
    Shahid Electronics Sep 27, 2008
    You don't need to pay for service manual on that site as its free there.
    Just give model number in search box and download all 7 parts of file free.
    Shahid Electronics Sep 28, 2008
    Hopefully you can get parts for your tv here and here.
    Please check Horizontal Oscillator and Drive circuit, if this section will function, you will get required voltages.
    Please pay attention on horizontal deflection area in your tv.
    did you found some thing in horizontal deflection area?
    does horizontal out put transistor work?
    Shahid Electronics Sep 29, 2008
    Alright, as you gone through in service manual and know very much about tv, please disable protection circuit for a while to figure out what exactly problem in tv and what circuit area is giving problem.
    This suggestion needs very much care when apply.
    Genius:
  • 2,920 Answers
Your power supply has gone out.it will need replaced.if all you have is a flashing red led you need to have a tech come out and repair it
  • Ronnie Houston Sep 27, 2008
    its a high vlotage area which is why i suggest you have a tech come out to look at it.it has enough power to grab you and not let go.call a shop near you and see what they tell you but im 100% sure the power supply is out. ron
  • Ronnie Houston Sep 28, 2008
    change out the power supply tim it will fix the tv
  • Hitachi Master
  • 19,396 Answers
If E994 has continuity , then C701 is ok. defective C701 gives problem with colors and picture.
If there is no led flashing, and does not turn on at all then is the power unit, test the capacitors on the power board.
  • 5 more comments
  • Ginko
    Ginko Sep 27, 2008
    Here is a list of the components that can cause shutdown:
    I401
    I601
    C715
    E995,E996
    T702
    Q777,I901
    E994,D724
  • Ginko
    Ginko Sep 27, 2008
    If the red led is flashing, then probably is not the power board.
    In your TV the power supply PWB, watching at the back, is the one on the right. At the left you shopuld have the main PWB.
    To troubleshoot the problem download the service manual at page 32 and following, then follow the troubleshooting diagrams. There you find what components to test.
    I post again the service manual, all in one part, is the same posted by welcomjee
  • Ginko
    Ginko Sep 27, 2008
    The link to service manual was a free download, you do not have to pay, normally the service manual costs $20 or $30, in Adobe.
    I told you to read the service manual because you need to follow a diagram telling you what to test.
    If the red led is on, then are not the capacitors on the power board. You need to troubleshoot the problem testing components one by one.
    This is the part of the diagram for your situation, when red is on and green off:
    Test filter coil Q914, and proceed from there, that is what you need to do.
  • Ginko
    Ginko Sep 27, 2008
    To test the filter coil, you short it, If you still get no picture you test voltage at Q701, must be 0.3v, then follow instructions on components to be tested.
    As usual, if you do not have done a similar job before, call a technician.
  • Ginko
    Ginko Sep 27, 2008
    I mean the job involves working on TV with live power.
    This is an hazard if you do not have a solid background in servicing electronics.
    If you want to make it ieasier, test all components at the end of the diagrams, and thest the components I posted before.
    You do not need to work with live power, as all you need to test is parts for continuity.
    It takes longer but often you spot the problem the same.
    If you know what you are doing, then follow the diagram.
  • Ginko
    Ginko Sep 27, 2008
    To download the manual, click this link: service manual, all in one part, then click the download button, then follow instructions, download is free.
    Thanks
  • Ginko
    Ginko Sep 28, 2008
    You can get parts here, just click.
    Or try here.
    If you cannot find the part give them a call.
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
BLINKING GREEN LIGHT AND WILL NOT POWER UP
You can check the Error code by doing the following.
On the Front panel hold down the Device and Menu Button for 5 seconds. The LED light will then start flashing the first set of flashing lights is for the "1"5 part of the code it will then pause for about a half second and start the ones place 1"5". The code will repeat 5 times before going off.
The Error Codes: 12 - Normal Operation; 21 - X-Ray Protect; 22 - Short Protect; 23 - Loss of Horizontal Deflection; 24 - Loss of Vertical Deflection.
The problem may also be in the power supply when you first plug the device in check how many times the Led blinks if it blinks for just over a minute the power supply is working fine. If the Led blinks repeatedly and does not stop the DM is not running.
This is a link to the service manual for you TV,
http://www.service-manual.eu/model.php?id=2710
Mar 02, 2011 | Mitsubishi WS-65909 65" Rear Projection...
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
No raster, no sound on 53UWX10B
double check the wire connections, as the filaments not being lit makes me thing a wire isnt connected properly, or one may have been loosend while doing the convergence repairs.
Jun 12, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 50ux26b
Good day, 1gary;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
May 17, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Wont power on
Needs Convergence amps replaced. Also fuses around this board are out. There should be small pico-fuses open around this board(replace)
Aug 26, 2007 | Hitachi 55FX48B 55" Rear Projection...
Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
489 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
