1985 toyota Camery in hot weather the car AC quits and will not engage the pump. After it cools the pump will come on again. When this happens the AC button in the car blinks. i know this is a vacuum and/or temperature sensor but i don't know which one it is. The manual I have does not say anything about it. Other wise the AC works just fine. Ron
  • 2 more comments
  • Ron0293 Sep 27, 2008
    When I first turn it on the AC is working fine, blowing cold air all the time, the clutch pump is in gauged...when the problem occurs the clutch disingauges and then no cold air..
    When I first turn it on the AC is working fine, blowing cold air all the time, the clutch pump is in gauged...when the problem occurs the clutch disingauges and then no cold air.. It is a sensor somewhere telling the pump to turn off.
  • Ron0293 Sep 28, 2008
    there is nothing wrong with the whole AC system when the compressor is pumping! no holes, no leaks, no heater problems or fan problems. The compressor keeps cutting out when the temperature starts to climb. I believe the system has a motor vacuum load/temp. sensor that cuts the AC out when the motor temp. rises from extra load. IE: like going up a long hill. I just don';t know where the sensor is located and the clutch wiring from the compressor is impossible to follow, as it is buried in a wire harrness.
  • Ron0293 Sep 29, 2008
    There are two fans located at the rear of the radiator. They don't seem
    to be running when the AC pump cuts out. There is a sensor switch on
    the dryer. when the pump is acting up if i disconnect the sensor wiring
    the fans start running on high. There is also another sensor on the
    pump and when i disconnect it the fans start running on high. replacing
    the wiring returns the fans to off.
    There is also a sensor, seems to be internal on the pump and when I disconnect it nothing happens.
  • 958 Answers
Hello ron,
let me explain.
your ac is working fine until the ambient temperature rises.
i am thinking two things or maybe one....you said it is a 1985 camry?...i am not sure if that year the compressor has this thermal overloads that cutoff the compressor coils as the compressor overheats.
compressor overheats because of lack of oil, over worked because of high pressure which is normal at high ambient, or mechanical problem with the compressor to make it overheat
this thermal cutoff is located sometimes at the top of the compressor or at the rear of the compressor. look for a part with two wire in it and the other wire connects to the coil of the compressor.
another theory is that the high pressure switch is being triggered by the high pressure due to high ambient temperature.
that is normal. that is what it is supposed to do. either deplete some gas so that it would not trigger the pressure switch or we look for the reason why the pressure is getting too high.
do you have auxiliary fan in front of the condenser?..and is it running? or do you have two fans at the back of the radiator?...are they both running when you turn the ac on?...
let me know in order to help you further...use the ask me button so that you won't be confused who is answering you.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
  • francis rivero Sep 29, 2008
    hello again ron,
    i dont know if you are answering my questions but it would greatly help us communicate if you could address us by using our names in giving comments. you do nut know but the set up with fixya is that you could only see one solution whereas we as experts could see all of the solutions the other experts gave. so there is confusion between us whom you are refering your comment to.
    anyway, just to inform you further,
    normal ac operation:
    1 switch ac on, compressor runs, two blower runs at low speed.
    2 if the switch of the dryer is triggered, meaning it detects a high pressure, it would turn both fans at high speed.
    either temporarily ;
    a.) i say temporary untill the pressure goes back to its normal level and turns the blower to its normal speed.
    b.) temporary if the thermostat would cutoff the compressor,( room already cold ) then pressure would go down, fans will turn off, and wait for the compressor to turn on again. if it turns on, it will run again at normal speed since the pressure is still low.
    or permanent. as long as the compressor is engaged, the fans will continue to run at high speed when the pressure of the dryer does not go down to its normal level . why it woud not go down?
    a.) ambient temperature is really high.
    b.) overcharged with refrigerant.
    c.) dirty condenser, clogged with dirt and leaves, anything.
    3. if thermostat is reached, compressor will cut off, fans will caut off too.
    4. if thermostat is triggered, compressor will run again with low blower and repeats its cycle.
    question; how many wires are there in the pressure switch in the dryer?
    how many are there in the compressor?( the one when you pull triggers the fan)
    let me know again, to continue trouble shooting your problem.
    tnx,
    drcool
    Master:
  • 479 Answers
Please check out the ventilations as something would be blocking the cooling line.OR there will be a minute hole in the cooling line so the ac starts for sometimes and then stops as the air gets leaked out from somewhere.
OR
If the AC unit has a condensor check its pressure and make sure that it is working properly with the unit, I.E. condensing the warmer coolant quickly back to a useable form, otherwise recharging the refrigerant is pointless. Also, check your heater valve. It could be that your AC is working fine but when your vehicle gets warmed up then you're heating your nice cool air before you get a chance to enjoy it!
OR
One reason is engine overheating - check your temp gauge and coolant as a first step.
Posted on Sep 27, 2008
    President:
  • 1,263 Answers
You have several sensors for the a/c system. if the system is running fine and cut's out chances are that it's not a sensor issue i believe that the clutch relay is weak and won't keep the contacts closed so just repalce the relay and this problem will go away. generally if the sensors detects either a blockage or a loss of pressure then the a/c will go on then off with in seconds not when it's been running. please rate the solution.
  • Ronald Mueller
    Ronald Mueller Sep 27, 2008
    incidently the post of namizhka is not even close. the fans have nothing to do with the condensor and as far as the evaporator core yes it's a good idea to keep it clean,but has nothing to do with the a/c clutch operation.
  • Ronald Mueller
    Ronald Mueller Sep 29, 2008
    according to the information you are giving me it is the expansion valve that is the prblem this regulates the a/c system this is located near the evaporator core under the dash. replace this and things should be ok from there
    Scholar:
  • 148 Answers
IF YOUR A/C WAS COOL FROM THE START AND THE LATER ON THE COOL WAS OUT EVEN YOU ARE RUNNING ON HIGH/LOW SPEED, CHECK THE EVAPORATOR IT NEEDED TO BE CLEANED.
BUT IF YOUR A/C WAS COOL FROM THE START AND THE LATER ON THE COOL WAS OUT BUT IF YOU ARE RUNNING ON HIGH SPEED THE COOLING WILL BACK, YOU HAVE TO CHECK THE FAN CONDENSER IT COULD BE BROKE AND NEED TO BE REPLACE.
KEEP ME UPDATED
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 27, 2008
Engine suddenly quits with no warning
Without knowing where the sound is coming from, theres no way to know if it is important.
Is it possible the noise is the ac clutch, and the ac compressor is locking up and killing the engine ?
Sep 24, 2012 | Cars & Trucks
Ac intermittently quits working, just replaced condenser, put dye in system at mechanics- no leaks
Have an AC repair shop hook up a set of AC pressure gauges while this is happening to see what is going on. You could have a defective AC compressor or a low refrigerant charge in the system. And as to the hot weather causing it to act up that would be normal, the AC would cool fine the cooler the outside air is, problems like worn out compressors and low system refrigerant charge levels would only show there ugly head in hot weather conditions. Also make sure the cooling fans fo rthe AC and engine are working properly. Good luck with this.
Jul 11, 2012 | Cars & Trucks
Engine runs great and then quits and will not start.. After waiting a few minutes it starts. This problem happens randomly. Car will be fine for a long time, then will just quit as above. 1985 Porsche...
Hello there
I sthis problem happening while the engine is cold or hot?
It could be you fuel pump,or for start try to change your fuel pump relay.It has to be RED not a black one.(round relay in your fuse box)
let me know
proporsche@yahoo.com
proporsche
Aug 02, 2011 | 1985 Porsche 911
I have a 2003 camery le six cylender with double fans that is over heating . On the highway the temp gauge stays in the middle section but in stop and go traffic it starts to rise and the air conditioner...
stop and go traffic will make the car heat up,, make sure you have air flow through the radiator fins, also make sure that the ac fan is actually engaging the fans work on a sensor and if they don't work, neither does the fan.
Jul 22, 2011 | 2003 Toyota Camry
Car stalls while driving. Will start after about five minutes. Is not flooded. Doesn't usually do this until after it has been driven a bit. Does it more in warm weather. Check engine light sometimes...
I'd have fuel pressure tested. I had a 95' did same thing. Cold winter day, worked fine, as soon as it got warmer, or hot out, it would quit, and re-start 20 minutes later and go for a distance then die again. If I parked in the shade on a hot day, I'd get further before it quit for the first time. I started carrying a fuel pressure gauge with me. Cool in the morning my fuel pressure was up to spec @ 49-50psi. Once it got warm/hot out and it died, Hooked up gauge and it was at 2-5psi. Let it sit and cool off 20-30 minutes, pressure would jump back up and run good until fuel pump got hot again and then pressure dropped off and car quit. It sure sounds like the fuel pump, but the hard part will be getting the car to the shop at the right time, or they will need to let it run on the lot until it quits to confirm the pressure drop. One thing you can try is when car quits, have a can of WD-40 or quick start with you and a screwdriver. Loosen the clamp on the air intake hose where it connects to the front of the throttle body and pull it off. With vehicle off, turn throttle linkage so the plate opens up enough to spray WD-40 a second or 2 in the throttle body. Then try to start it. If it starts and runs momentarily, then you can be pretty sure it's fuel related and my guess is the pump needs replacement.
Apr 12, 2011 | 1996 Plymouth Neon
When I get stuck in traffic in real hot weather I get a vapor lock and I just run out of fuel to the carburetor. The engine will restart if you prime the carburetor 1985 Chevrolet C 3500
Not an expert here but hope this helps. I had an 85 GMC Van and the previous owner had installed an electric fuel pump in engine compartment. I too would stall when hot. I finally relocated fuel pump to underneath the van and it ran cool and no more vapor locks.
Oct 31, 2010 | 1985 Chevrolet C3500
1985 300d turbo
AC charge, AC dryer, Low pressure sensor, High pressure cutout, engine temp sensor, AC compressor bad, AC relay bad. CCU can be bad but I doubt it.
Jun 10, 2009 | 1985 Mercedes-Benz 300
Cuts off in warm weather after about 10 miles
Don't rule out fuel pump. Had a 95 do the same, ran great when cool in morning then when it got hot in afternoon, it would quit. Wait 15-20 minutes & go again, sometimes got me home, other times a few more miles until it cooled down again. Luckily I had access to a fuel pressure gauge. Cool in morning had 49 psi, when it quit, 2 psi. Wait 20 minutes, 49 psi again. If you can drive it around until it starts to act up then run into a repair shop for fuel pressure test it will confirm it. If not, they may need it all day to monitor the fuel pressure & confirm it is pump. If your a gambler, change it & fuel filter. One thing I did get was trouble codes indicating a lean mixture, due to starving for fuel. Have you cycled your key to retrieve any codes yet?
May 20, 2009 | 1996 Dodge Neon
Toyota 89 camery
Is it new or rebuilt? There is a big difference. Also a starter is not supposed to click.
IT'S SUPPOSED TO ENGAGE!!!
Have you confirmed the connections in both the starting and charging circuits?
Dec 28, 2008 | 1989 Toyota Camry
AC button blinking
hi mercedes,
here is another thread that is almost similar to your problem, i just paste it here with my reply...
posted by Ron0293 on Sep 27, 2008 Report abuse
1985 toyota Camery in hot weather the car AC quits and will not engage the pump. After it cools the pump will come on again. When this happens the AC button in the car blinks. i know this is a vacuum and/or temperature sensor but i don't know which one it is. The manual I have does not say anything about it. Other wise the AC works just fine. Ron Comment by Ron0293, posted on Sep 27, 2008When I first turn it on the AC is working fine, blowing cold air all the time, the clutch pump is in gauged...when the problem occurs the clutch disingauges and then no cold air.. Comment by Ron0293, posted on Sep 27, 2008When I first turn it on the AC is working fine, blowing cold air all the time, the clutch pump is in gauged...when the problem occurs the clutch disingauges and then no cold air.. It is a sensor somewhere telling the pump to turn off. Comment by Ron0293, posted on Sep 28, 2008there is nothing wrong with the whole AC system when the compressor is pumping! no holes, no leaks, no heater problems or fan problems. The compressor keeps cutting out when the temperature starts to climb. I believe the system has a motor vacuum load/temp. sensor that cuts the AC out when the motor temp. rises from extra load. IE: like going up a long hill. I just don';t know where the sensor is located and the clutch wiring from the compressor is impossible to follow, as it is buried in a wire harrness. Comment by Ron0293, posted on Sep 29, 2008 There are two fans located at the rear of the radiator. They don't seem to be running when the AC pump cuts out. There is a sensor switch on the dryer. when the pump is acting up if i disconnect the sensor wiring the fans start running on high. There is also another sensor on the pump and when i disconnect it the fans start running on high. replacing the wiring returns the fans to off.
There is also a sensor, seems to be internal on the pump and when I disconnect it nothing happens. if(typeof LIB_LOADED == 'undefined'){document.write(''); } Add a Comment
Oct 01, 2008 | 2002 Toyota Camry
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
