Question about Whirlpool Kitchen Ranges
Newly installed Whirlpool Oven Control Board makes BUZZIN' noise
I believe a power outage messed up the Control Board to my Whirlpool oven model RF365PXMT 2. I purchased a new CONTROL BOARD (part # 6610454) and installed it.. For some reason it makes a buzzin' noise when i plug in the oven and when I try to bake something. Any suggestions?? Thank you in advance...
Oven ==> http://www.appleappliances.com/product.php?model=RF365PXMT
Control Board ==>http://store.valueweb.com/servlet/zapplian/-strse-12855/Biscuit-Electronics-Controls-Boards/Detail
catriver
  • 878 Answers
SOURCE: Oven Control not working
Vahid, is the display black, nothing there? Try pressing the bake and broil pads together for 3 seconds until display shows SF. Then press clock. If this doesn't work try the ERC test by doing this; Kill the power to the range for 10 seconds. Press the cooking time, delay start and number 8 pads all together. The display should show the word test. Give this a shot first....Catriver..post back.
Posted on Nov 12, 2006
  • 60 Answers
SOURCE: bottom oven does not heat up, top oven works
the most common problem for your description is that your bottom ignitor is not working properly just because the ignitor glows doesnt mean your ignitor is working it has to draw 3 amps or more to ignite the bottom burner part number for the ignitor is 12400035 let me know how you make out
Posted on Sep 12, 2007
fridgetech
  • 473 Answers
SOURCE: maytag gemini MER6769BAW
Power to that element comes directly from the oven control. If you have replaced the element and all wiring is ok then the control is bad even if you hear it clicking. The part # is 74006213 and cost is $298.99 @ http://www3.sears.com/.
Part # for http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48695 is AP377973 and their price is $230.53.
Posted on Nov 11, 2007
aborcass
  • 2651 Answers
SOURCE: Frigidaire electric range smooth top with no oven function
although you dont have hte model number , that is indeed a correct and valid part number for the control lists for a about $120. since your back there give a quick look at the wiring into the unit, is that ok ??? adn where the burnout is on the control does it appear to have shorted out against the back wall??? perhaps a relay on the board just blew??? i really wouldn't thinkn tha another component was goning to make that go bad, also ck the bake and broil elements for continuity, perhapa wire fell off the element blowing out the control
Posted on Mar 20, 2008
SOURCE: Jenn Aire Model SVE47600W
Thank you so much for this information. I can verify that this procedure worked (at least for me). I ordered the part from Digi-Key Corp (it was up to a whooping $.28), replaced the old capacitor, plugged everything back in and bam! A working display. There was a beeping and error message but after hitting the Cancel button on the stove, everything was working.
Note that this fixed the dimmed display only. All the other controls were still working--only the display was off. If you have other issues, this might not be a complete solution.
You need basic soldering skills, a small solder iron, a solder ******, and some rosin-core solder. The capacitor is labeled on the circuit board.
When taking the unit off the control panel the largest ribbon cable was clear plastic with embedded contacts. I'd never seen one of these before. The cable's contacts slide in behind the pins on the connector and are held against it by an insert in the connector. When I removed the insert, the clear plastic cable came completely out from the connector. I had thought I'd broken it. But just slide it back in behind the pins, aligning the cable contacts with the pins and put in the connector insert to hold them in place.
The Digi-Key part number for the capacitor is P10292-ND. I ordered 5, just to have a few spares. The 5 caps plus first class postage came to a total of $3.51. Quite a difference from the $160 for the whole unit!
Thanks again to ultigerfan for making this information available.
Posted on May 07, 2009
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
After a power outage / low current power problem this evening, my whirlpool range, Model # SF315PEKW0 started beeping annoyingly, and displayed the following code F1 E1. Also, after, the oven would not...
The "F1-E1" fault code signifies an EEPROM checksum failure within the electronic oven control. Disconnect power to the range for longer than 30 seconds. Re-apply power and observe the display for longer than a minute. If the failure remains, disconnect power and replace the electronic oven control board.
Jul 24, 2011 | Ovens
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Timer beeper failure on Whirlpool Gold oven/range oven
Most of the beepers I am familiar with are built into the main control clock board assembly. The only way to repair this is to replace the whole main control board, not a cheap part.
Jan 10, 2010 | Whirlpool GY396 Electric Kitchen Range
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Jun 24, 2009 | Whirlpool RBS305PD Electric Single Oven
Whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
Mar 24, 2009 | Whirlpool RF368 Electric Kitchen Range
We had a power outage today during the self cleaning process of our double oven.. The Electronic Oven Control panel is dead. No lights of any kind. The circuit breaker is ok. Upper door is locked.
Turn the breaker off for 5 minutes. this will reset the system. If you still have no power then it spiked your control board and it's the board that is fried.
Please remember to leave rating before you sign off
Dec 20, 2008 | Whirlpool GBD307PDS Electric Double Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Kitchen Ranges Logo
65 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
