Canon power shot sd110015 will not upload pictures to the computer. i put in the CDrom and installed it already but when i connect my camera it said that device software had failed.
  • aleksp Feb 18, 2009
    i don't know how to upload pictures from the cannon onto my mac!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Posted on Nov 20, 2014
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: I have a Canon Power
Go to start>run. Type in msconfig, under startup, see if there is something referring to the canon software. If there is, un-check the box next ot it.
Then go to the control panel > add/remove programs> scroll down and see if you find the canon software. Delete it from here. Then try to re-install.
If it is not in add/remove>
you may have to go into the registry and delete all mention of the software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 10, 2008
How do i re-import pictures from my canon power shot d10 to my computer after having done once? i lost the pics and it doesn't allow me to re-import again because i did it once already.
Remove the memory card from camera, put it into a reader and connect the reader to the computer via the usb port. Then using windows explorer locate the folder where your pictures are, create a new directory in your computer hard drive, and Copy the pictures you want into your hard drive.
Sep 27, 2016 | Canon PowerShot D10 Digital Camera
What mode should camera be in to upload pictures does it matter if you connect usb cable to ccamera or computer first
It should be in playback mode. It doesn't matter if you plug in camera first or computer first but it does matter that you have to first install the proper drivers for your camera on your computer. The proper drivers is on the CD that came with your camera. Install that first before connecting your camera to your computer. Personally, I don't like to connect camera to computer unless I'm doing an update to the firmware. I would suggest buying a USB memory card reader if your computer/laptop doesn't have one already. Then I upload my pictures by removing the memory card from the camera and plug into the USB card reader. Best of luck.
Feb 28, 2011 | Canon PowerShot SD1000 Digital Camera
How do you upload pictures on the internal memory?
If you normally upload your pictures by connecting via the USB port, remove the memory stick before connecting the camera to the computer. If you normally upload your pictures by putting the memory stick into a card reader, use the camera's memory stick tool to copy the pictures from internal memory to memory stick.
Nov 15, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Canon power shot won't upload pics. "Cannot connect to device."
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place? Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
May 17, 2009 | Canon PowerShot SD1100 IS Digital Camera
Uploading Pictures To The Computer.
If you are running Windows XP or Vista in computer, hook USB cable between camera and computer, power up camera, Windows will recognize it and install required drivers automatically, click My Computer, Removable Disk, click folder and copy picture files and paste in some where in computer.
May 14, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
CANON POWERSHOT A460 IS NOT RECOGNIZED BY COMPUTERS
The first thing I would do is go the the canon website and download and re-install the drivers for it.
Oct 09, 2008 | Canon PowerShot A460 Digital Camera
Uploading digital photos
Hi there
The A530 is equiped with a socket that allows you to connect to a USB connection on your computer. You will need the lead that came with your camera. Look for any spare USB socket on your computer. It looks like a small plain rectangular shape, mostly with a flat white strip inside it that will match the plug on your camera's lead. Make sure your camera is switched off, then connect your lead. Switch the camera on when it is connected and your computer should atutomatically detect it. It should say "Found new hardware." If you get to this stage, you're on the right track.
Next, launch the program you installed from the software cdrom that came with your camera. This should guide you through the next stage and allow you to send your photos to your computer.
If they are important, be sure to back them up so that if your computer breaks down or is stolen, you still have your photos.
Feb 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Unable to upload photo to computer.
as far as i think VISTA is not compailant with the CANON software. since vista s a latest version CANON will have to release a new version of its software for VISTA.
so this must be requested with CANON.
Nov 14, 2007 | Canon PowerShot A550 Digital Camera
Computers & Internet Logo
416 people viewed this question
David Payne
David Payne
