Usb hard drives
Can you load discs on a usb hard drive and run them on an office pc? I have a typing program on disc to teach typing. I want to use at work on my lunch hour. My office pc has a disc drive but it cant be used to load anything.
    Genius:
  • 1,447 Answers
Hi-
Yes you can load a discs into it but only the softwares for it or drivers to be exact, how ever there are application that will allow you to install a program to your USB drives. try portable apps, search for it on google so you'll know the details and compatible programs for it
Hope this helps
Posted on Sep 27, 2008
How to move/copy user files to external hard disc (wall or usb powered) so that productivity applications default-save to the external hard disc (virtual drive) folder via ...
When you connect an USB drive to a Windows machine, or a Mac the drive is shown. On a Windows machine in the explorer with a new drive letter, like D: or E: on a Mac it is on the desktop with a name.
Then you can access it as any other drive. But if you are using program's like Office, you have to tell the software what drive and what folder is the default folder to save your data.
In explorer and on the Mac with finder, you also can move files around to any folder you want. On the internal drive or to the external drive.
Oct 29, 2014 | Computers & Internet
Tip
Using CCleaner to speed up slow Computers
Computers have 2 main types of memory that the user has control over. Memory that is on a Hard disc Drive and memory that is in RAM. When a program runs it loads its data from the Hard Disc Drive into Ram. Now, usually we have lots of extra Hard Disc Drive space but not necessarily Ram and if your computer is sluggish reducing the programs running at any time may greatly boost performance.<br /><br />Now when you install a program a lot of the times it adds itself to startup meaning every time your computer is turned on that program starts. Now you may only use that program once a week but its continuously running wasting resources. Managing your startup programs with a free program called **** Cleaner can greatly increase performance.<br /><br />download CCleaner from <a href="http://www.piriform.com/ccleaner">http://www.piriform.com/ccleaner</a> and install it<br /><br />run the program and select the tools tab on the left of its windows<br /><br />next click on start-up<br /><br />you will see a list of entries under start-up now technically you don't need any of these running for windows to work, however you may want say windows live messenger running in the background the whole time so pick and choose which ones you wish to disable from start-up.<br /><br />I personally like to disable and remove every start-up program. I only like programs running when I tell them to run, and not wasting resources.<br /><br />cheers<br /><br />djbr1ck
on May 13, 2011 | Computers & Internet
Tip
How to fix a computer that will not boot
If your computer will not boot (i.e. it won't start up), you can fix it by utilizing a set of recovery discs.
I recommend the Windows 7 recovery disc, which can be downloaded from here. It works with Xp, Vista, and Windows 7.
(*Note: it will comes as an .iso file. You can either use a program like PowerISO or Nero to burn it to a CD or you can use a .iso burning program to extract the contents to a USB drive.)
  1. Load the recovery disc into the CD-ROM bay (or plug in the USB if your going that way).
  2. Restart your computer and boot from the Recovery Disc (this can be done by pressing BIOS options, shown at when you first power on your computer and changing the boot order so that the CD or USB boots before your hard drive.)
  3. Select the option "Repair your computer". Choose your operating system, select next, (if any prompts come up, select no- we want to fix our computer manually) and then click on Command prompt.
  4. You should see a blinking black box with a white cursor. Type in
bootrec /fixboot
press enter, then type
bootrec /fixmbr
type in exit, then select restart. Remember to remove the Cd (or USB) before you click on restart.
After that your computer should start be back to normal
on Dec 01, 2009 | Computers & Internet
Computer wont start or boot up cursor line on top blinks please help ?
Your computer can't find the OS on your hard drive. Most likely the boot sector has been damaged (or someone reformatted the drive). The entire hard disc may have failed.
Since this is a netbook, you will either need an external optical drive (USB) and a copy of the OS to boot from or a USB flash drive that has been prepared as a boot version of the OS. HP offers the Mini 5101 with WinXP Home, SUSE Linux or FreeDos. There may be newer versions with other OS options. Make sure to get the correct OS, even if you upgraded it.
You will need to boot to the optical drive or the flash drive. On other computers, this may involve accessing the BIOS to change the boot order. Look for a splash screen with the key information. Then turn off the computer and turn it back on while repeatedly pressing the key. (F1, Esc, Del, and F10 are common keys.) If you miss the timing, turn off the computer and try again.
If you are using XP, you will need to enter the Recovery Console. Then enter the command line mode. If your command prompt starts with any character other than C. Type C: then press Enter. Next type CD WINDOWS. Then try the BOOTCFG /REBUILD and see if a Windows OS is found. (type the command in and then press enter). Then type in the command FIXBOOT. This repairs the boot sector. You will need to confirm the commands. Type CD .. and CHKDSK /R /F to check for and fix damaged hard drive areas
If this worked, type EXIT. Try rebooting the computer. Otherwise use the command FIXMBR and then exit. Enter the HP recovery program (on the original hard disc or on Recovery discs, if you made them). Restore the computer to the original configuration with that program. If you ever did anything to repartition the hard drive, the recovery partition may not be accessible. You will lose any stored files and need to reinstall any programs you added to the netbook.
I hope this helps. Please note: losing this part of the hard drive may indicate that you have a failing hard disc. You will need to decide if you want to replace the drive or the netbook. If you decide to replace the hard drive, match the original drive size and data/power specifications (2.5" drive and SATA cable, probably). Use a USB/SATA/IDE hard drive adapter and a cloning software either added to the hard drive or from an optical disc to transfer the OS to the new drive and then set it as the boot drive before installing it in the netbook.
Sep 22, 2012 | HP Mini 5101 Netbook - HEWLETT PACKARD...
I had publisher loaded on my computer. It would have been 2003. The computer crashed and I am now unable to use this programme. The icon is still on the desktop and is in My Documents, however when I...
if you have the program on a disc you could uninstall it then turn off your computer then reinstall it
or
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 31, 2010 | Microsoft Office Professional 2007 Full...
I have a mini notebook and would like to install office 2007. I cannot install using a cd rom since there isn't one. is there another way I can do this?
Install it from a hard drive... or.. set your pc on a network then share the cd room on the other pc ot he network... run and install the application...
Dec 30, 2010 | Microsoft Office Professional 2007 Full...
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
External hard disc not accessible
hi there...if this thing happen to your external HDD you have virus in your external hdd. so the solution is connectthis external to your pc/notebook then if already detect by system don't try to explore it or else just click cancel if system ask at popup windows.
in windows explore at your exernal id double right clik and choose format with default allow size...wait for a minute ( depend how big the size of your external). and don't forget to close all program first (music etc) when you formatted.
about geeting your external data back you can use program Office Recovery.install it at your pc and you can backup your data using : office recovery--media heal for hard disk....
good luck
Feb 02, 2009 | Computers & Internet
Usb flash drive can't be recognize anymore by the pc..
test with "H2testW" , if the program works and tells you you have errors, run "PD V1.08 B3"
if when selecting usb drive and it states to insert disc... it's stuffed.
Jan 28, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
