Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Electrolux Advantage series but the electric in the brush not work
Where online can I find a diagram for the brush..there is no suction and it doesn't appear to be clogged..but there is suction in the hose..Cottage195@yahoo.net
  • cottage195 Sep 28, 2008
    This was my problem and this was exactly how I solved it...be altert that when you plug the nozzle part into the solid handle one side is nothing just a space and the other side is the plug..just take note so you learn from my failure.
I fixed it when someone called to my attention that I had put it together again trying to plug the power nozzle into an empty space and not making the electrical connection. Guess the rain had me operating in **** mode.. so let this be a lesson...
Posted on Sep 28, 2008
My Electrolux Ergorapido seems to have no suction. The handheld works fine. I cleaned everything out of filter and from the roller brush. Any help please?
remove the blockage in the hose when it pivots on the suction head
by necessity this area is narrow and is easily blocked by paper , hair and small wired items toys and the like
Sep 18, 2017 | Electrolux Vacuums
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Vacuums
New bag indicator will not reset causing bare floor mode not to work at all and mode 2 not to vacuum dirt properly
Your top motor (suction motor) isn't running. Your vacuum has two motors in it. The top motor is the suction motor that runs on the first switch position and the bottom motor (brush motor) turns on with the second possition.
It could be the switch.If it isn't the switch, the only other thing it could be is the motor itself.
To check the switch, unplug the vacuum and then take the three screws out of the back of the handle. If you are comfortable with electricity, jump the black wire and the blue wire togeather and plug the vacuum into a electrical outlet. If the motor dosen't run, the problem is with the motor. If the motor runs, the switch is bad and needs to be replaced. You can get one at most any vacuum shop.
The motor could be bad or the carbon brushes can be stuck with dust. This is more involved and I recomend taking the vacuum to a vac shop that works on the "old" Electrolux vacuums. The new name for the "old" Electrolux is now Aerus Lux but you would probably get it repaired less expensively at another vacuum shop.
If you want to go into the motor housing you'll have to take the big screw out of the back of the handle and pull up on the handle to remove it. Next, remove the four screws holding the top half (motor housing) of the vacuum. Two screws on the back and two screws to the front inside of the bag housing. You'll need a long #2 phillips screw driver. Then pull up on the bag housing with a side to side motion.
With the housing removed, you will see the motor and can lift it out.
Check for any bad winding. You can smell them to check if you can't tell by looking at them. If they are burned, you will need to replace the motor.
To check the brushes, you will need a 5/16th" socket to remove the two bolts on the top of the motor and lift the top bracket with the carbon brushes off and see if the brushes move freely. If not moving or not long enough to touch the top part of the motor with the copper bars (the comutator) it would be best to replace the motor.
To reassemble the vac just reverse.
This is a long and difficult prosedure and I reccomend that you take the vacuum to a repair shop that works on the Electrolux.
Feb 09, 2014 | Electrolux Vacuums
My Electrolux Precision Brushroll Clean Bagless Upright Vacuum, EL8807A Won't Start. I Plug it in and turn it on and nothing ... no motor sound no suction, it has a burn smell. The brush will roll but the...
The burn smell means you should take it to a qualified Electrolux repair facility. It may be an electrical issue and could catch on fire if not repaired properly.
Oct 25, 2013 | Electrolux Vacuums
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Suction/Brush not working
Hi there SmartAlec from NelsonVacuums.com.au here.
There are a couple of common reasons that your electrolux vacuum cleaner would appear to have lost it's suction. The first and most common is that it has actually broken a belt. If the belt is broken the brushes won't spin and it will not pick up dirt. It is easy to test simply turn the vacuum on, release the handle (as if you were about to vacuum carpet) and lift up the head and see if the brushes are spinning. If not i can supply you with a new belt.
If the brushes are spinning then your next most likely cause is that there is a blockage in the vacuum somewhere. Test this by turning machine on and checking the suction at the hose (as if your were going to vacuum the couch) if it is poor then remove hose and fish out blockage. If it is ok you may have a blockage between hose and the brush of the vacuum.
If it is neither of these problems i can trouble shoot over the phone if you live in Australia 0269215200 or by email nelsonvacuums@netspace.net.au
Happy Vacuuming.. :)
Aug 25, 2009 | Electrolux EL5010A Bagged Upright Vacuum
Brushroll in electrolux oxygen+ deluxe
Is the brush roll not working at all? Check the teeth at the sides of the brush roll by opening up the electric head. If it has completely been destroyed you may have to buy another new head for it. Separate brush rolls are difficult to obtain and work out more expensive sometimes than the electric heads themselves.
You may have to contact the Electrolux cust services in your own country. Check by Electrolux.com
Jul 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
165 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
