Question about Miele Washing Machines
Miele premier plus w806 front load washer leaks (but not extensively) when spinning and water is being discharged.
5 Suggested Answers
  • 16 Answers
SOURCE: Wate rleak Miele premier 300
The conditioner part of the drawer is still blocked. Take the drawer out and turn it over, on the bottom of the drawer you will see what looks like a blanking plug, it's about 1" or so in diameter. Carefully, prise off the plug with a flat blade screwdriver, and you will find lots of sludge blocking the syphon path. Remove syphon and and run hot water through until you can see daylight through the syphon hole where you just removed that blanking plug. Re-fit blanking plug giving it a little tap home. This should sort it.
Posted on Feb 08, 2008
SOURCE: kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Posted on Apr 26, 2009
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
SOURCE: washing machine not spinning
I had a similar problem and about a week later it didn't wash at all.
Turned out the water inlet valve (one of the three) was faulty. The rubber seal/seat had a small hole and wouldn't open to allow water into the machine.
I wasn't prepared to pay the $213 for a new one so I went to our local appliance spares place and found one that was similar and used the rubber seal/seat from that to replace it. It was an electrolux single inlet valve part #360313 (from memory). Cost me $37. Could've got it for $22 delivered off ebay but I needed it asap.
Posted on Jun 05, 2010
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Water leak on spin cycle no warning lights on
If there's water underneath the machine, check drainage pump. Most likely gasket or simmering. If necessary replace pump (about $45,00).
Apr 25, 2015 | Miele Novotronic Premier 500 Front Load...
Washing machine not spinning
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section appliance will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent ( Y - Piece) from drain pump blocked.This requires front panel to be removed.
If the machine detects a fault then an indicator light will flash,(rinse light for motor circuit).
Apr 22, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier Plus - no water into the machine
Plug off the wall. Unscrew the hoses that bring water to the machine, check the fine meshes on hose as well as machine, clean out well with tooth brush (not yours), see that pressure is good in your wall socket. Refit carefully, check for leaks.
Feb 26, 2009 | Miele Novotronic Premier 500 Front Load...
Miele w 427 not pushing out the water after the wash cycle
the drain pump may be blocked by a piece of debris - clean the filter out on the lower front of the machine and check for a obstacle blocking the pump.
Nov 25, 2008 | Miele Novotronic Premier 500 Front Load...
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Miele washer-dryer
you have activated the float switch in the base of the unit due to a water leak. this could be just excess detergent or an actual leak. if you tip the unit forward with some towels in front this will drain out the water. try running again with no detergent. if it doesn't show WPS after a couple of washes then you are ok. then change your detergent.
May 31, 2008 | Miele Novotronic Premier 500 Front Load...
Jan 07, 2008 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
75 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
