Question about Brother MFC 420CN All-In-One InkJet Printer
Ink settings The window on the printer keeps telling me that the yellow ink level is low. I have reinstalled a new yellow ink, I have checked it's installation and it still tells me the ink levels are low.The ink is full. The product of my printing shows no yellow on the print out even though it is full.
  • Anonymous Sep 29, 2008
    My problem is on an MFC3360C printer.
    All the color cartridges show "almost empty" except cyan which shows
    empty All these color cartridges are brand new right out of the pkg
    Bobschus80
    President:
  • 2,712 Answers
Have you made sure you removed the backing plastic from the cartridge sensor?
Try reinstalling the driver and do a nozzle and head alignment test. If you still have the same issue, try doing a hard reset - unplug the printer from power and PC, wait for about 10 minutes and replug everything and see. If the issue still occurs, there could be an issue with the cartridge sensor on your printer, which will require servicing.
Posted on Sep 27, 2008
Put new cartridges in my canon mg5250 only printing black and yellow no other colours
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Oct 18, 2011 | Office Equipment & Supplies
My canon ip1900 lights keeps keep blinking green and yellow back and forth and it wont print
Thank you for using FIxya
Sep 13, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Green and yellow lights blinking
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 19, 2011 | Office Equipment & Supplies
I have a canon pixma mx320. I purchased on line refillable ink cartridges. The problem is the printer will not let me copy, print or even fax. The screen keeps reading black ink volume level not readable....
Go into the Canon Printer Utilities. Click on Solution Menu folder. Click on Solution Menu icon.
A new window will open up. Click on "Change settings or find solutions to problems.
A new window will open up. This screen will give you 3 selections to choose from.
They are: Printer Settings, Printer Status and Troubleshooting. You will be able to reset your ink cartridge levels from these windows and try to print again.
Dec 22, 2010 | Canon Office Equipment & Supplies
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Yellow ink cannot be recognize by the printer
The problem is that the priter can't detect the ink, because the cartridge has low level ink. I put scotch tape and colored it yellow- on the part where the ink is detected - so the printer will detect the color I put on the tape. BUT as others said it can damage your printer if you will always do this.
Jun 24, 2009 | Brother DCP 130C All-In-One InkJet Printer
When i run a test pattern on my mfc 420 it will not print the yel
Clean the yellow printer head with the self cleaning function. Try printing yellow from a computer, etc. Check ink level, make sure it is not telling you low ink.
Jan 12, 2009 | Brother MFC 420CN All-In-One InkJet...
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Ink tanks are running low... BUT!
Have you changed anything on your pc such as installed updates windows or interent settings, this can often adversely affect printer fuction as many printers cannot handle certain settings and operating environments. I would first clear all printing jobs (click on printer and select cancel print queue or similar message. Now turn printer off, disconnect all cords and usb cables. re plug and turn on and try again. You can also check printer driver function, go to start, control panel, perf and main, hardware, scroll down to your printer, see if any yellow exclamation marks. This could mean a driver problem. It may be incompatable if you have changed anything or it may be malfunctioning due to spyware or other. I also suggest running full anti spyware and virus checks. I all this fails, try uninstalling and reinstalling the printer.
Aug 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
493 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
