Question about Maytag Atlantis MAV8000
Maytag top loader MAV 8000MWW
Washer suddenly will not turn on. Power to washer ok, no power from control panel to motor. Control/ timer not engaging.
Think timer is bad but not sure how to confirm other than repair service.
  • john gagnon
    john gagnon May 11, 2010
    hithanks for the question is there water coming in
    President:
  • 2,712 Answers
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Posted on Sep 27, 2008
Maytag MAV 8260 AWW Does not work at all. No water flow, no spin (even when filled with water from hose) Does it have an internal fuse? Where is it located? Is the large timer switch the brain of the...
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Nov 02, 2013 | Maytag MAV7600 Top Load Washer
I have a Maytag washer MAV 6200AWW - is the Maytag timer #2605660 the same as the timer #22003371? Thanks, Scott
Hell Scott,
i do believe the part number for your washer model number is 22003371and when searching the part number 2605660 none of my 4 parts lookup websites can not find that part number but yet all of them tell it the timer part number for model# MAV6200AWW is part #22003371
Sep 10, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Top load Maytag washer about 20 years old. Fills OK with water but will not agitate. Cannot hear timer ticking at any time. Thanks.
You might have a sensor problem that prevents the cycle from proceeding.
Most washers have a sensor that detects the water level, thus allowing the selection of Small, Medium and Large loads and the related water level.
Some sensors also use a breather tube, which can become clogged with fluff or debris, causing the same symptom.
Only when the sensor activates, will power be applied to the timer or rotary control unit's little motor, thus causing the cyle to proceed.
Feb 12, 2011 | Maytag Washer Timer - 22004015
I have the maytag washer mav 7000 aww; The Timer does not work automatically but works when moved by hand to each function. This is a 120 volt 60Hz machine and since i stay in a country, where we...
Open the control console.
Use a voltmeter to test the timer motor.
Set the machine to wash.
Place the meter leads on the 2 timer motor wires.
If you read 120 volts and the timer does not advance,the timer motor is bad.
The complete timer will need replacing.
Sep 22, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Maytag alantis MAV 9600
hi thanks for the question re set the water level control to see if it will add more water if it doesn,t it could be a bad water valve check that thanks the appliancedoc
Sep 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Wont work at all
Need to know the model number and serial number before I can assist you
Jan 09, 2008 | Maytag Atlantis MAV8000
Washer problems
Mardokenly, start with the door lock assy. It looks like power has to go through the wax motor assy (door lock)then the light before getting to the main control board. With the power off and harness removed from the door lock mechanism it should ohm out at 950 to 1100 ohms at room temp. If this passes the test another area to look would be the timer and control board. If the control board does not see a change in timer inputs after 5 minutes of power to it, it will shut the washer off. Things to check would be loose connections at the timer and control board. They have had a lot of service bullitins and service flashes out on this model. One of which has to do with the loss of the nuetral line from the power cord to the control board. When this happens, of course the washer will shut off. You may want to call Maytag and see if you are covered under these service bullitins. Catriver..post back.
Feb 19, 2007 | Maytag Neptune MLE2000A Front Load Stacked...
Washing Machines Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
