Question about Akai LCT3201AD 32 in. LCD Television
Akai 42 in. Plasma
I turn on my TV and after it has been on for about half an hour I get shadows of different colours. Especially on the right hand side. Plus i do have satalite and in it at times I see the guide to different stations. This doesn't do it on all chanels but the best of them. Please help me. Plus I need to down load the manual to my TV, because I have misplaced it. I purchased it on April 10,2007.
Thank You Penny
    Genius:
  • 1,550 Answers
You can download the manual from the link below
Akai manual
SAM ANDERSON
Posted on Sep 28, 2008
    Guru:
  • 558 Answers
Sorry I think you had given the incorrect model no. So it is difficult to found out the Manual for it.
Akai Official website showing 16 models in that category which you have mentioned here:
"Check out using this link"
Try to reset the TV by pushing the button manually, then by remote. Leave it unplug for 10 min. then try.
Give me more information so I can investigate further.
Ellin
  • Akai Master
  • 19,396 Answers
Shadows on plasma TV are often related to the power board that supply plasma screen volatages. When the board is giving wrong power on the vertical refresh you get shadows.
Similar phoenomena are also caused by bad connectors, and in less frequent occasions , because of a defective plasma screen.
If you want to do it yourself get the service manual first.
If you decide to call a repairman, or you need to validate the guarantee, call the number listed on the owner manual.
My tv has sound but no picture its an akai model pdp4206em1
Try unplugging it for an hour or so or try change sources , if the computer ever fell asleep while it was plugged in it is possible it triggered a sleep mode in the tv. Most will do such a thing. It is doubtful that the computer caused any damage to it but i would advise against using a plasma tv as a computer monitor because burn in WILL eventually occur with a static image left on the screen constantly.
Dec 26, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
LG plasma TV with white shadow to right of bright colours? can it be fixed?
Yes you need to replace the controler board,part number 6871QCH038A.It is located under the tuner board,so you will have to take it out to get to it.
Oct 03, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
Sep 23, 2009 | Televison & Video
Akai 42 in Plasma
This sounds like your flyback needs replaced on the main circut board! (if out of warranty it should not cost that much to fix!)
I hope I was of help!
Dec 12, 2008 | Akai PDP4225M 42 in. Plasma Television
Monitor display had problem .
Hello Lunhoo,
Your TV should still be in warranty. If so, yes you should take it in for repair. Even if it's not in Warranty, Akai may have a special warranty extension for your TV. Check it out.
Good luck.
Feb 28, 2008 | Akai PDP-4216M 42 in. Plasma Television
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Vertical Red Lines
IS IT AN LCD ? IF SO IT MAYBE THE CONNECTOR ON THE LCD PANEL THET USUALLY GO DRY JOINTED
Oct 08, 2007 | Akai PDP-4216M 42 in. Plasma Television
AKAI PDP4273M Plasma tinted red
TRY THIS BY USING YOUR REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER THIS WILL TAKE YOUR TV BACK TO FACTORY PRESETS. I WENT 3 MONTHS WITH NO TV BEFORE I FOUND THIS OUT.
Sep 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
42 inch plasma
TURN OFF THE MAINS AND THEN SWITCH IT BACK ON
Jun 06, 2007 | Samsung HP-R4262 42 in. Plasma Television
Akai LCT3201AD 32 in. LCD Television Logo
107 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
