Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
E 2 and F 9
We have a problem with our copier, what does E 2 and F 9 mean? It also show a paper jam, we can not find it. Will you please help.
  • 2,072 Answers
That can mean differnt things depending on the model you have.
Please let me know the make and model and I can give you a more complete answer.
I can tell you E2 normally means a paper jamming issue, but can be related to the connectors and or circuit board. So please provide me the model number and I will provide better informatin for you.
Posted on Sep 28, 2008
Add showing jam paper while start copier
Hello Dear,
This means that paper is stuck inside the roller.
  • Please switch off the copier, open the panel where paper goes inside and try to remove the paper manually.
  • Make sure no paper pieces are left inside.
  • Once done, start it again and load paper slowly so that it does not get stuck.
Happy Printing!
May 15, 2016 | Office Equipment & Supplies
Display shows paper jam, but no paper in machine.
Turn it off and on.
Try disconnecting the printer from power and from the PC.
Leave it as such for a while before connecting again.
Feb 28, 2012 | Brother MFC-5440CN All-In-One InkJet...
I have a mita dc 1460 issue. The Display shows me an error code J01. This means it has a paper jam problem. Can anybody help me.... I would try to hard reset it but I don't know the key combination .....
I have the same problem. I used the manual, followed the steps but can not find where the paper jam is. is there any way to open up this unit like most copiers do to get to the paper jam???
Feb 10, 2011 | Office Equipment & Supplies
Error 3 is showing it also says swith off and on
this error mean : paper jam (location) it mean a non specific paper jam occored
follow this step to fix:
1. remove jammed media fro the specified location
2. verify the paper tray is fully closed
3. inspect and/or replace the feed and separation roller
4. ensure there is no obstruction on the path, such as a torn piece of paper
5. open and close the top cover to clear the messaage
6. check sensors andflags for proper operation
i hope this helpful
thanks for using fixya
Jan 28, 2011 | HP LaserJet 3055 All-In-One Printer
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jams - we got copied from mom that passed away - no manual. We don't know what the symbols mean. Trying to score a manual but immediate problem is that paper stops feeding. Error message says there's...
Unfortunately, I can't direct you where to score a manual either. The jam in this case means that paper did not travel far enough into the copier within the correct amount of time. It is possible to clean the feed roller, (with enough patience) I suggest using IPA (rubbing alcohol). Hope this helps.
Aug 06, 2009 | Canon PC-425 Color Copier
Please clear paper jam and press ok
hi i josh in cebu phils. may i help you? friend the paper jam means there is something blocked your paper feeder try to clean or check if there is something in there may be a paper pencil clifs etc. try to clean and restart the printer.good luck
Feb 19, 2009 | Office Equipment & Supplies
Amessage '' misfeed detected'' please remove the .... from 0
before i can help you you need to tell me which brand and model is the machine.
The Message "misfeed detected" means that a paper is bee jammed inside of the copier so you should open some door and remove the paper which has been jammed inside of the copier.
Because of that i need the brand and model of the copier for i to be able to help you and tell you what to do
Jan 29, 2009 | Office Equipment & Supplies
Paper jam
HP has a web page on its site that shows you how to clear a paper jam for this printer:
Paper Jam Solution.
Good luck.
Oct 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
