Question about Hamilton Beach 22502 Digital 2-Slice Toaster
Digital Display no longer showing, lever won't stay down
My Hamilton Beach 22502 Digital 2 slice toaster was purchased about 3 months ago and worked perfectly up until two days ago. I noticed that the digital display was no longer lighting up. I made sure the toaster was plugged in, no display showing the toasting level. I then tried actually putting bread in and pushing the lever down. The lever won't stay down. When I hold the lever down, it toasts fine. This leads me to believe that the digital display not appearing has something to do with the lever not staying down since the heating element portion of the toaster still works.
What could cause the display to go out? Is there anything I can do to fix this on my own?
  • 11 more comments
  • jennx9999 Sep 30, 2008
    Thank you both for your help. I found the original box the toaster came in and it came with a 1 year limited warranty. I will be shipping it back to Hamilton Beach to get a replacement.
  • Anonymous Dec 02, 2008
    Lever will not stay down, and the LCD on the front is no longer showing! Worked fine until this morning..Only bought it two months ago
  • Anonymous Jan 22, 2009
    We had the same problem 4 times. No lights and the lever doesn't stay down. The 1st one went bad after several months and we sent it back and they sent us another one that lasted a few months and then the same issue. The 3rd one they sent lasted 6 days and then the 4th one lasted 6 days. They are now investagating the problem but we no longer want this unit.
  • annas13 Jan 25, 2009
    I have the same problem. This is my second 22502 toaster and after using it for 2 months, the LED is out. I am so frustrated, especially that I did not keep the box so not a big chance of replacing it with the new one. Will never buy Hamilton Beach product again!!
  • gcap1 Feb 07, 2009
    I have the four slice toaster with two LED displays - one morning the display on the right is off but the one on the left is on - the two slice toaster on the left works fine and the one on the right does not work at all - electronics are dead. I bought this toaster just this past Fall - about five months ago at KOHLS. I actually had all the receipts and manuals for everything I ever bought up until a few weeks ago when my wife became frustrated with my pack rat ways and forced me to throw all the paperwork out except major appliances (TV, Washer, etc) As she said our old toaster lasted twenty years - what can happen to a toaster?
  • Anonymous Feb 22, 2009
    Yet another toaster that doesn't light up and won't stay down! Ours is a 24502 four slice model, and it is the right side that doesn't work. Something in the manufacturing process? Interesting that another person with this very toaster has the same problem on the right side! Got it for Christmas--was purchased at Kohl's. We moved at Christmas, so the chances of finding that receipt are slim...guess we should have looked up problems with the model before we bought--live and learn. Definitely won't buy this model again (or any other Hamilton Beach, for that matter).
  • Anonymous Mar 12, 2009
    I have the exact same problem with my 22502. I don't have the original receipt, but I am going to try to get a duplicate receipt from Target since I used my credit card. Will let you know how that works out.
  • fibbermcgee Mar 16, 2009
    I'm all set to replace the diode... but I can't get the case open. Got the 4 screws out, now what?
    I'm sure I'll be fine when it's just me vs. the electronics.
    OK, used a screwdriver to pry the case off, no problem. How did you get the board out to work on it?
  • perrywrogers Mar 25, 2009
    I got the first one for Christmas. It made it through January, but had to be returned to the store at the start of February. It is now mid-March, and the second one is now doing the exact same thing.
  • bloosqr Apr 18, 2009
    Blah I have this exact same problem with a target hamilton beach toaster :(
  • jfb275 May 17, 2009
    We have the same problem - obviously these toasters (the electronics in them) should be recalled. Can't locate receipt and no box - will try a return anyway.
  • Anonymous Mar 20, 2014
    The handle will not stay down when I push it. If I hold the handle down the taster comes on and begins to toast
Jsullivan22 is right about the diode. I have this problem with my 24502, which is a dual version of this. There are 2 circuit boards in your unit one with the LED display on it and another one. The diode needing replacing is on the other board. it is in the center of the board, right next to a large (1/2W or 1W) 2K ohm resistor. The diode is probably part number 3ez24d5. Test it with the diode test on your DMM, if it is bad you will get 0V both directions (I think). Also if you measure it with the Ohm function it will probably measure less than an Ohm (check the zero on your DMM as many are not accurate down this low) You can probably replace it with a <a id="ctl00_ContentMain_CartGrid_grid_ctl02_ctl00_lnkManufacturerPartNumber" rel='nofollow' href="http://mouser.com/Search/ProductDetail.aspx?R=1N5934BGvirtualkey58410000virtualkey863-1N5934BG" style="font-weight: bold;">1N5934BG</a> or a <a id="ctl00_ContentMain_CartGrid_grid_ctl03_ctl00_lnkManufacturerPartNumber" rel='nofollow' href="http://mouser.com/Search/ProductDetail.aspx?R=1N5359BGvirtualkey58410000virtualkey863-1N5359BG" style="font-weight: bold;">1N5359BG</a> Mouser stocks both of these&nbsp; (currently). I haven\'t gotten my parts so I can\'t guarantee these will work, but I\'m pretty sure. I will try the latter first as I\'m hoping it\'s higher power rating will keep it from burning out again, although I will be buying several spares. <br><br>This is clearly a design issue with these toasters and one that could be easily corrected. Both circuit boards in my toaster are very toasty in the area of these diodes, although I\'m sure the fact that these boards are mounted very close to the heating elements doesn\'t help their longevity.<br><br>Hope this helps everyone.
Posted on Jan 31, 2009
  • schallman Jan 31, 2009
    Sorry about the html in here this website was being a little stupid, for those of you who can't figure it out here are the links:
    1N5934BG1N5359BG
YOU HAVE A DEFECTIVE DIODE THAT LITES THE LCD. A .99 CENT PART. SELLER SHOULD REPLACE THE TOASTER WITH OUT QUESTION.
Posted on Sep 30, 2008
I bought a Hamilton Beach 24502 toaster that I exchanged twice and the toaster that I have now has failed on both sides. I have disassembled the unit and found the same conditions as described by Schallman. My question is did you receive the diodes, replace them and did that fix the toaster?
Posted on Mar 07, 2010
  • ray99504 Mar 22, 2010
    I wish to give my thanks to Schallman for the information he gave for repairing the Hamilton Beach model 24502 toasters. The information he gave was right on. I purchased two (5 watt) 1N5359 Zener diodes and replaced the diodes as described by Schallman, the only thing I added to the repair process was to leave the leads long and mount the diodes away from the circuit board, so they could disperse any heat away from the board. The toaster has been working for some time now and I hope this is a long term fix. I invite Schallman to stop by for some toast.
    Ray99
I am having the exact same problem with the Hamilton Beach 22502 toaster. One morning I woke up and the LED was out - and the toaster wouldn't toast. The frusturating thing is that this the SECOND model 22502 that I have had this problem with,
With the first, I had the toaster for about 6 months, but unfortunately threw away the box and manuals (come on, who saves a warranty for a toaster). So, out $50. This was the second priciest toaster at Target (so I guess you DON'T get what you pay for).
Bought a second, identical Hamilton Beach 22502 model last week at Target. This time I kept the manual and recept. Sure enough, this morning, the toaster died - showing the same issues at noted above.
This toaster's going back to Target this afternoon. I will tell you - I will NEVER purchase another Hamilton Beach product again. Two toasters - bought six months apart at Target stores in entirely different parts of the city (so it's not like a bad manufacturing run) - both dying after extremely minor usage.
Very, very poor quality! Stay away from Hamilon Beach toasters!
Posted on Oct 28, 2008
  • iwcba Dec 10, 2010
    schallmans solution for a hamilton beach model 24502 was exact.
    i found the diodes at newark electronics for 67 cents each
    zener diode 1n5359bg.
    changed out the center diode and the lights came back on from the dead.
    the toaster is working fine
  • 247 Answers
I don't know how good consumer protection law is in your part of the world, or what sort of warranty you've got - but if that happened to a toaster I'd only bought three months ago here in the UK, I would expect a no-questions-asked refund.
The lever not staying down and lack of display are likely to be symptoms of the electronics which control both having gone pop.
It is possible that if you open the toaster up, you might be lucky enough to find something like a blown internal fuse - but I suspect the chances of success are not high.
It is a near certainty that if you open the toaster up and subsequently try to take it back for a refund, the vendor will decline to play on the grounds that you've been tampering with the unit.
A.
Posted on Sep 27, 2008
Need instruction manual for hamilton beach 2-slice toaster
Hello, az
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Oct 14, 2011 | Hamilton Beach 22502 Digital 2-Slice...
I need a diode for a Hamilton Beach Model 24502
I order mine thru Digikey.com for 4 pieces
total cost is $3.94 including $2.05 postage.
Dec 28, 2010 | Hamilton Beach 22502 Digital 2-Slice...
Handle will not stay down
It has to be adjusted through the temperature knob. You change the temperature and the main handle will get locked in down position. Just
Dec 26, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Toaster will only toast on one side
Is there a cancel button for this? It might be stuck. Check this and let me know
Feb 07, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Only toasts one side of toast
The cancel button is stuck in the in position
Jan 13, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Hamilton Beach 22505 toaster info
Usually, four screws under the bottom remove the top but the toast loader lever knob is usually press fitted on. Some units have bent tabs to hold them together if screws are not used. To remove the knob, freeze the unit (to shrink the knob/lever) then place a flat piece of wood like a ruler wrapped in cloth on the housing behind the knob and use a large bladed screwdriver to try to work the knob off. If you break it superglue and epoxy, and drawer knobs not plastic or wood might work as a replacement.
Nov 05, 2007 | Hamilton Beach 22505 IntelliToast 2-Slice...
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Hamilton Beach 22502 Digital 2-Slice Toaster Logo
1,722 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
