Question about Cyber Acoustics CA-4400 Computer Speakers
Cyber Acoustics CA-4400 Computer Speakers aren't working with new sound card intel 82801i onboard the motherboard using linux OS are there special settings?
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: I can't seem to get my cyberacoustics to work (Speakers)
Hi, Perhaps the beeping sound you hear at start up is the internal speaker directly connected to the motherboard. If you Device Manager or your Control Panel/Sound & Audio Devices Properties/Audio tells you that nu such device is installed, what you need to do is re-install the necessary drivers. To confirm if the sound card is there/working but need drivers, go to your Device Manager, a yellow marked "!" will indicate that that component need drivers/re-installing. Post back with your motherboard brand/model that we may look for drivers or use the original motherboard CD installers. Good luck and kind regards.
Posted on Aug 22, 2007
Chillimar
  • 115 Answers
SOURCE: drivers
Usually (95%) speakers dont use drivers. I have one small speakers that for laptop that connects by USB port, but xp can find these drivers byself.
Posted on Dec 10, 2008
  • 130 Answers
SOURCE: How can i fix my Ca (cyber Acoustics) computer
www.cyberacoustics.co support and there you will find the new adaptor available
Posted on Jan 11, 2010
Riztech
  • 731 Answers
SOURCE: I just installed the Cyber
Disconnect the speaker source cable from your computer and to a MP3, CD Player, or anything else with 3.5mm headphone jack. If your speakers work on this source, you know are okay. And the issue lies on PC or Connector/Sound card.
Also please tell me, if you were able to hear sound with other speaker or headset.
Regards,
Riztech
Posted on Jun 16, 2010
livingmentor
  • 143 Answers
SOURCE: i just bought new cyber
1. Verify that the speakers are plugged into the correct jack on the soundcard.
2. Check volume on both the speakers as well as Volume properties on the computer. You may have mute checked or the volume turned down.
If neither of the above correct the problem, you may have an issue with your soundcard. Try uninstalling and reinstalling the driver. If all else fails, you may have a faulty soundcard.
Posted on Oct 31, 2010
The right main speaker has no sound but the left side and subwoofer work just fine
if the speaker has been at all moved the wire could have broken i currently have a cyber accoustics ca-4400 set and the wires are very flimsy looking and i previously owned a ca-3001 set and the sub wire on the 3001 broke after a simple move up from my basement and i went through like 4 power supplys on it until i just bought a non cyber acoustics supply so cyber acoustics cords are VERY flimsy and that may be why you are getting no sound from your right speaker
Mar 03, 2013 | Cyber Acoustics CA-3001 Computer Speakers
Low sound from speakers
either bad quality of preamp or the speakersistem has some probblems
Apr 22, 2012 | Cyber Acoustics CA-3080 Computer Speakers
My speakers are plugged into my computer and the outlet but they still will not work. Model CA-2014
Make sure the have the audio drivers form the computer you will need to find the drivers for the sound card if you will give me information for your computer such as make /model and operating system I can help you with that
Sep 06, 2011 | Cyber Acoustics CA-2014 Computer Speakers
I just bought new cyber acoustics ca-2014 computer speakers from office depot,they do not work on either one of my computers it doesnt even recognize them hooked up,is there a download for my computer to...
Oct 31, 2010 | Cyber Acoustics CA-2014 Computer Speakers
Hi;My cyber acoustic speakers worked on my other computer;now I have a Dell flatscreen and need to know the process on how to get these to work;Thank You Donna
If you are connecting them to a diferent sound card , make sure they have drivers installed...Connect wires properly , and it should work fine.
goodluck :D
Dec 29, 2009 | Cyber Acoustics CA-2016 Computer Speakers
Only got sound threw 1 speaker, everything is connected correctly.
were did u get the drivers from my mate as i am in the same sh..
May 27, 2009 | Cyber Acoustics CA-5150 Computer Speakers
Aug 22, 2007 | Cyber Acoustics CA-2012 Computer Speakers
Re:ca-3000 speakers
see there is power on speaker and check the audio cabe connection is it properly connceted to audio jack in your sound card. bye
Aug 09, 2007 | Cyber Acoustics CA-3000 Computer Speakers
Cyber Acoustics CA-4400 Computer Speakers Logo
41 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
