Question about Philips 50PFP5332D 50 in. Plasma Television
Shutdown; red LED blinks 4x
Turn on the unit and the relay clicks with a solid green light then the relay clicks again and the red LED blinks in intervals of 4x. The screen never lights up. Is there an error code that coincides with the 4x blinking? I am a bench tech in need of some guidance/help/assistance. Philips MODEL 42PF5321D/37 thank you, carl i have a 42 inch doing the same thing , unplugging it only fixed the problem 1 time and had it unplugged all day - was told told to download software upgrade but cannot put on to tv if you cant see the screen? Is this worth repairing?
3 Suggested Answers
jdbouncer
  • 72 Answers
SOURCE: shutdown; red LED blinks 4x
The Error 4 is refering to a I2C4 communication error between SSB (small signal board), and the Logic board ( located underneath the SSB (under the bracket). Very high probability the SSB is bad. current replacement SSB 12nc is 313926809052
Posted on May 01, 2008
my fujitsu is only playing in black and white how do i sort this
Posted on Jun 19, 2008
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
Jan 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
The most likely reason for the no picture might be the back light is gone and needs to be replaced, now as for the LED light blinking on different intervals is because its diagnosing it self unfortunately the user manual does not have any information on this part only by contacting the Phillips customer support you might get a better idea, but check your back light first it may just be that. Also try to check your Manufacturer warranty repair.
Sep 07, 2007 | Philips 50PFP5332D 50 in. Plasma...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Philips 50PFP5332D 50 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
