Question about Miele Premier-Plus Built-in Dishwasher
Miele door won't open
Hello, when i push the open button of my miele novotronic W831, nothing work. The door remain closed. Evrything seem to work well except the door
thanks, by advance, for your response
olivier
4 Suggested Answers
SOURCE: Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Posted on Mar 16, 2008
  • 132 Answers
SOURCE: I have a Miele 590G dishwasher. Everything appears
you must to check also the tap of water which connect water to this small box may the water pressur out from tap is weak .
you can use a small pan to help this test.
thanks ross
Posted on Jul 07, 2009
  • 177 Answers
SOURCE: the door on my miele G481 built in dishwasher won'...
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
Posted on May 24, 2010
  • 177 Answers
SOURCE: 23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
Posted on Jun 13, 2010
Miele dishwasher g1220sc has stopped working. There is no electrical activity viewable in the control panel. Has anyone experienced this before? Any solutions / suggestions?
Hi Lisa itsounds like a door latch , if it goes bad it has two safty switches on t to prvent useing the dishwaser while the door is open,before you order any parts check to see that you still have power to the unit , check braker
Dec 16, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
Miele Turbothermic G579SC Dishwasher Intermittent Problem Dishwasher works fine on approximately 30 per cent of times it is used. This percentage seems to be about the same whatever program is selected...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 07, 2011 | Miele Dishwashers
The door on my miele G481 built in dishwasher won't stay open it's really annoying that it keeps popping up when I'm trying to load.
hi,
Hope this helps
May 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
hi,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele g 851 sc i have a leak under the unit (below the right door hinge) when i run the machine
hi,
make sure you are not using too much detergent. no more than 2 teaspoons. try running the unit with no detergent a few times. if problem still persists then check the door seal or remove the door panel and make sure the overflow tray running along the base of the door where the hinges are is not blocked with food. also check the door is closing enough to seal,the door latch may have moved. check the tightness of the screws
Nov 20, 2009 | Miele 24 in. Novotronic G851SC Plus...
Circulation pump is stuck
Hello Stonegroup,
The impeller is located below the bottom filter trap. Remove the tray and at the twelve 'O' Clock position you will see a small opening. Inside there are the pump impellers. take the Hackenschlussel (Hook spanner/Miele tool) and insert it in the opening and turn. You should turn it a few times and be able to feel the impellers free up. Also, Make sure you run the dishwasher atleast once a monch to avoid the circulation pump getting stuck like this
Sep 17, 2009 | Miele 23 in. Novotronic G841 Built-In...
No start
hello i'd check to see if theres a glass fuse in side the dishwasher it will be on the power board good luck
shaun
Aug 31, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Mar 15, 2008 | Miele 24 in. Novotronic Premier 500...
Miele Premier-Plus Built-in Dishwasher Logo
108 people viewed this question
Top Miele Dishwashers Experts
icatci
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
