My Aurora AS1010TX paper shredder will not shred paper. It will work in reverse.
    Genius:
  • 2,120 Answers
If you want to attemp to take the machine apart, there should be a small spoked wheel called a pulse sensor that runs through U-shaped black device.
Blow this out as well as all electric devices inside.
Posted on Sep 27, 2008
Its not working and shredder wont turn on
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and poke at any compressed paper wrapped around the blades - can take a while. Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 27, 2014 | Aurora Electronics AS1010TX Cross-cut...
Motor runs in reverse but not when I want to shred paper
My as702mx can run reverse but not auto run , please tell how to fix, and get new similar one how much
Oct 15, 2011 | Aurora Global AS702MX Shredder
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
My AS101bCD Aurora shredder will not shred paper, green light on paper in nothing, will happily go in reverse, what can i do
Sounds like a problem with the switch. Replacement is the most likely option, switches cannot normally be repaired.
Jan 26, 2011 | Aurora Electronics AS1018CD Shredder
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
The aparatus that pulls the paper into the shredder doesn't work
Check to see if cutting shafts are turning in either forward or reverse operation. If not and you can hear the motor running the take off cover and check plastic gear drive train...probably something broken in there.
May 25, 2010 | Aurora Electronics AS662C Shredder
Shedder one works
This is an issue with the paper feed sensor which may be a electronic eye or a mechanical switch if it is mecanical you may just have to jiggle the switch a few times, occasionally paper may get stuck behind it not letting it activate. If it is electronic you have bad sensors or bad pc board and you'll have to contact the manufacturer for further info.
Mar 07, 2008 | Aurora Global AS501X-MS Shredder
Shredder stops after about 10 minutes
spray the sheddred wheels with wd40 or any lubricant
Jan 18, 2008 | Aurora Electronics AS1010TX Cross-cut...
Aurora AS1010TX Will run forward for 1/3 of paper then into reverse.
I'm going to say it needs oiling. Try oiling the gears and cutting blades. You can buy paper shredder oil at Office Depot or Office Max.
Jul 10, 2007 | Aurora Electronics AS1010TX Cross-cut...
Shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
May 20, 2007 | Aurora Global AS501X-MS Shredder
77 people viewed this question
jasbo
jasbo
