Question about Krups FBC112 1600 Watts Toaster Oven with Convection Cooking
Krups fbc2 toaster oven cuts off while toasting
I have just bought a krups fbc2 6 slice convection toaster oven.  My husband has found that while toasting bagels on the middle shelf (he likes them well done).. the toaster oven sunddenly cuts off (the clock is interrupted) and the start stop switch becomes inoperable -  he says it remains on and it does not respond to him trying to turn it off.   Any idea why this should happen??? (we have to constantly re-set the clock).   Is this an electic mal function or short circuitry issue?  Do you advise returning the product?  It is less than 1 week old.
Returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Posted on Sep 28, 2008
I need a Manual for a Krups Counter Convection Oven
Krups has one manual for the FBC2, FBC3 and FBC4 models. Start here: http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm and use the drop-down menu on the left to select Toaster Ovens. Then select the FBC2. Click on the green and black icon to download the manual. The direct link to the manual is http://www.krups.com/NR/rdonlyres/5605B757-078E-4DF1-9DED-A884209066C8/4351/TOASTOVENFBC234_usa.pdf . The manual is also available here: http://static.highspeedbackbone.net/pdf/TOASTOVENFBC234_engusa.pdf . You can also get this manual from the Krups FBC2 product page: http://www.krups.com/All+Products/Toaster+Ovens/Products/FBC2/FBC2.htm . Click on the Instructions link.
I hope this helps.
Jul 27, 2016 | Krups FBC4 1600 Watts Toaster Oven with...
The toast button does not work properly anymore, guessing there is something wrong with the contact?
My toast button did that for a while then got better. Also, try holding the button in for a few seconds instead of a fast hit.
Jan 27, 2012 | Krups FBC2 1600 Watts Toaster Oven with...
For HB 22708 Toaster Oven: Will it toast both sides of a slice of bread at the same time?
Yes, the Toastation works like a traditional toaster in the top slots. If it is not toasting both sides like a regular toaster then there is a problem. If that is so and if it is still under warranty, then contact the company for repair. If it isn't under warranty, then find a local repair business.
Mar 29, 2011 | Hamilton Beach 22708 Toaster Oven with...
I have a fbc2 krups convection oven and the handle is broken. is there a replacement for this?
Molly, there appears to be some replacement parts available:
this is a link for the oven door and handle, which appear to come together: http://www.smallappliance.com/product.asp?pid=2478&cur=USD&sid=18956&gid=18984&pfor=2805&shopBy=Category this site is referenced as authorized by Krups, but Krups did not show this replacement part in their online store.
this is a link for the tray handle: http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+SS%2D185298&MENU=parts&SELECT=toasterovens&SKW=PARTFBC2 for 1.99 from Krups, and http://www.smallappliance.com/product.asp?pid=2479&cur=USD&sid=18956&gid=18984&pfor=2805&shopBy=Category for 8.99 from smallappliance.com, referred by Krups.
Hope this is helpful.
Dec 22, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Sep 30, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Krups FBC2 Convection Toaster Oven Simply no power at all.
Having a toaster oven and a coffee maker on the same circuit is asking the breaker to trip in the house electrical panel, but I guess that you have learned the drill: only one appliance on at a time. Try moving the oven to the working side of the socket (the two socket sections can be spit apart and power each half from a separate house breaker and wiring). If the oven now works, check for a tripped breaker in the house panel. If the oven still doesn't work, look for a reset button near the cord entry point. Many heating type appliances have a thermal fuse that opens when things get too hot, but you need to get inside the cover where the cord enters.
Oct 11, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 30, 2009 | Krups Toaster Ovens
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
4 slice toaster blows fuse when toaster uses 4 burners
You will need to move it to a different outlet that is not on the circuit that you are using or just toast 2 slices at a time.
May 06, 2008 | Toastmaster 328 Toaster Oven with...
Krups FBC112 1600 Watts Toaster Oven with Convection Cooking Logo
355 people viewed this question
Top Krups Toaster Ovens Experts
warcraft demonhunter
Level 1 Expert
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
