Question about Sony Playstation 3 (PS3) Console
When the PS3 disc is loaded the introduction is fine and then the background becomes runny with color lines running from top to bottom. A kind of snowy effect.
    Sergeant:
  • 196 Answers
Output you have selected may be incompatible with your tv try changing the output in your ps3 menu
Posted on Oct 20, 2008
Background glitches in certain games, fall through sceenery
You must be sure that disc are clean and free from fingerprints..this tends to affect background..! Also if you are not online.. you must plug into ethernet/broadband to "UPDATE" ps3 software at least once a week..! and any new games you buy also require Online updates..!
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
Tip
How to Format an HP Recovery Drive
How to Format an HP Recovery DriveThe HP Recovery Drive is a partition HP puts on its hard drives for use in case the primary partition becomes corrupt or unusable. The recovery partition contains system files and the ability to boot and repair, format and reinstall the operating system if needed. For those who prefer recovery disks or who don't feel the need for the insurance of the HP Recovery drive, it can be formatted by following the steps below.
Instructions1 Open Disk Management by Right Clicking "My Computer" and selecting "Manage."
2 Click on "Storage" and "Disk Management."
3 Find the Recovery Drive partition. There are usually two partitions: the "C: partition" and the "HP_RECOVERY D: partition."
4 Right-click on "HP_RECOVERY D:" and select "Format."
5 Choose the File system and Allocation Unit Size and click "OK." The HP Recovery Drive partition will format and be available for your specified use
Tips & Warnings
Be very careful to not format the C: drive by accident.
on Dec 15, 2011 | HP Computers & Internet
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tip
How To Reset Your Mobile Phone
You can return your phone to its original state, as it was when it left the factory. This is also called a hard reset. You might want to do this if you are giving your phone to a friend or relative and you want to remove all your data first, or if your phone has a persistent problem that is not solved by powering off the phone and then powering it on again.
A factory reset is a drastic measure. It permanently erases all your personal data and customized settings, and also removes any programs you have installed. Make sure that you have backed up the information and files you want to keep.
As different phone models have its own reset procedure, view complete list here.
on Jul 09, 2011 | Cell Phones
Tip
How To Find Motherboard Drivers
How To Find Motherboard Drivers:
Here is a real world example on Fixya.com of some one having a problem getting drivers:
Question:
I need drivers for my FC GIGABYTE 8vm533m-rz motherboad
That is a some what a perfect question, the brand has been given and the motherboard modal number has also been given, so finding the drivers will be a peace of cake !
First of all, always go to the makers brand website, in this case we would go to Gigabyte's official website located here
Next, go to support & downloads;
Then copy and paste the motherboard modal number ( in this case is 8vm533m-rz )
From there we can get the drivers, located : HERE
locate the bios update: HERE
and that crucial mobo manual we all seem to lose: HERE
And that's the very basics, the same method would be used for every motherboard. Mostly all manufactures are happy to provide the drivers and support software on there websites.
Hope this helps some one out there.
on Jul 02, 2011 | Computers & Internet
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Tip
Unlock Your Nokia mobile phone with Code Calculator
What is Unlocking?
Unlocking a mobile phone is the procss of removing any SIM Card or Network restrictions set on the phone by either the manufacturer of the phone or by the mobile phone's service provider. After unlocking a mobile phone, you can still use it with it's existing network or switch over to any other supported network.
Get free unlocking codes here
on Jan 10, 2009 | Nokia N95 Cellular Phone
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
