Question about Salton /MAXIM Westclox 114661 Meteor Black Alarm Clock
Lexibook Meteo Clock Weather Station needs resetting - help!
I have a Lexibook Meteo Clock SM940 (light turquoise blue and silver). It has 1 remote control outdoor sensor and an indoor base sensor/clock. Batteries have run down and needs resetting - only I cannot find the manual. Please can anyone point me to either an online manual (I have searched with no luck) or could find the time to walk me through a reset. Many thanks.
  • Anonymous Nov 09, 2008
    i have exactly the same problem too!!!
  • chrismilleri Dec 07, 2008
    I have a Lexibook Meteo Clock with external sensor and internal display unit. Seems to be working okay but need instructions to use other functions. Can anyone tell me where I can get a copy of instructions.
    Many thanks
    Chris
If its the same as the sm1960 then try this put new batts in.The house code should flash usually code 1 for 8 sec. If you haven't changed it press c/f then set. Then on the main unithold CHN for 3 sec. As it pics up the signal it should beep after 3 mins it finishes learning and all is set. Hope this helps.
Posted on Mar 04, 2009
Make it 3
Posted on Nov 20, 2008
Lexibook meteo book sm1960
i have a problem with my rain gauge, i have tried new batteries and waited an hour for it to set itself and it still reads 000 in inches (accumulated 000 / today 000/last hour 000/yesterday .
tried reset button on rain gauge sill does not work/ **** also does not work.
do you think the rain gauge is at fault
yours faithfully a.dobson7@ntlworld.com
Posted on Feb 04, 2010
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
I have a Sharp SPC502 atmoic clock/weather station. No matter what I do I cannot get the outside temp/humidy to show up on the main station. Have tried changing channels, different alignments,...
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Dec 28, 2010 | Sharp Cell Phones
How to reset a Seth thomas weather station wall clock
what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
I'm trying to find a manual for my weather genius EM3302A indoor/outdoor remote thermometer, purchased from XS Cargo. I need the manual to tell me how to change the clock from a 24 hour clock to the 12...
Weather Genius EM3302A Remote Weather Station
Once all settings are complete you press the UP button to toggle back and forth between the 24 hour clock and the 12 hour clock.
Sep 23, 2010 | Vacuums
I have Acu-Rite 00754 Wireless Weather Station
Its a remote temperature sensor to read a aquarium or refridgerator or pool water temperature
Jan 22, 2010 | Acu-Rite Audio Players & Recorders
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Meteo
1. How do you know the meteo is wrong? Are you comparing against a known good measurement device?
2. The altimeter requires adjustment every few days or whenever there's a weather change. Select the altimeter, hold the upper or lower button until you have the correct altimeter reading for where you are and it will hold for a few days.
For example, I know my home is at 100m elevation (I checked on a topo map) so I reset it to 100m when I leave the house in the morning. It varies (in my case) by over 100m in either direction, depending on the weather.
Nov 03, 2007 | Tissot T-Touch T33159851 Wrist Watch
4,726 people viewed this question
Top Salton Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Salton Audio Player and Recorder Expert? Answer questions, earn points and help others
