Question about Garden
Engine starts but then stops when throttle is advanced
The engine starts when using normal starting procedures but when I squeeze the throttle to speed up the engine it stops.
  • 1 more comment
  • kennenor Sep 28, 2008
    30 cc String trimmere - purchased April 2008 very limited use - probably 10 hours or less - last weekend - started, runs, idles and dies when trying to accelerate engine. Changed spark plug, changed fuel, - same problem.
  • obman Mar 23, 2009
    Starts fine but cuts off when given gas. Have changed fuel,plug and cleaned screen.??????????????
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    does the trimmer head start to spin at all?
  • 18 Answers
Air/fuel mixture needs to be richened on the high speed adjustment
Posted on Jan 28, 2009
I have a John Deere Hydro 175 riding mower that has this strange starting procedure.
fuel flow or blocked main jet
have the carby overhauled and check for full fuel flow
Dec 22, 2017 | John Deere Garden
Engine idles a little high when in drive
check hoses for vacuum leaks also throttle body may need to be cleaned and or throttle body position sensor can be starting to be faulty or may require cleaning with throttle body --the following links show how to clean a throttle body look up the ones that do it in /on vehicle you dont have to remove it from vehicle
How to Clean throttle body GM 3800 throttle Body Tune Up Cable accelerator... Throttle body cleaning and idle relearn procedure
Jul 27, 2016 | 2006 Buick Lucerne CX
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why does 200hp mercury not srart first start of day
    You have to follow the starting procedure to avoid flooding.
    1. Pump primer bulb until firm
    2. Advance throttle 1/4
    3. Turn key to "on" and push in 6 or 7 times. This primes the
    engine by injecting fuel directly to the crankcase
    4. Start engine.
    Sep 11, 2014 | Boating
    Truck dies when idling
    HI
    first I would like to tell you, do this procedure only if the 5th digit of your VIN is C or K.
    Description
    The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle. Anytime the throttle body is cleaned or replaced, the ECM must learn the new throttle position. The idle may be unstable or a DTC may set if the throttle position is not learned.
    Conditions for Running the Throttle Learn Procedure
    • DTCs P0101, P0102, P0103, P0107, P0108, P0111, P0112, P0113, P0506, and P0507 are not set.
    • The engine speed is between 450-4,000 RPM.
    • The manifold absolute pressure (MAP) is greater than 5 kPa.
    • The mass air flow (MAF) is greater than 2 g/s.
    • The ignition 1 voltage is greater than 10 volts.
    Throttle Learn
    Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code
    (DTC) List - Vehicle.
    1. Start and idle the engine in PARK for 3 minutes.
    2. With a scan tool, monitor desired and actual RPM.
    3. The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
    4. Ignition OFF for 60 seconds.
    5. Start and idle the engine in PARK for 3 minutes.
    6. After the 3 minute run time the engine should be idling normal.
    Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
    * If the engine idle speed has not been learned the vehicle will need to be driven at
    speeds above 70 km/h (44 mph) with several decelerations and extended idles.
    7. After the drive cycle, the engine should be idling normally.
    * If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds
    and repeat step 6.
    8. Once the engine speed has returned to normal, clear DTCs.
    Good Luck
    Mar 04, 2014 | 1995 GMC Sierra
    Hard to start then misses sputters and dies at a stop
    Is this a "nose cone" harley?19 70s to 90s? Check centrifical advance unit,located behind breaker plate where points or ignition module are mounted.when they sit for awhile it can rust and stick,resulting in retarded timing.
    Jan 22, 2013 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
    Electronic Throttle Control Indicator Light dodge caliber 2007
    Stop using the car--period
    Have it checked for codes,road tested &
    diagnosed
    I think you have very bad ignition coils that
    put it into failsafe
    They are so bad they spike the computer &
    take out the throttle postion sensor signal &
    you get ETC Failsafe
    Can't use it like that-- it will ruin the exhaust converter
    Dec 21, 2012 | 2007 Dodge Caliber SRT4 Hatchback
    Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
    have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
    May 02, 2012 | Yamaha Boating
    Engine starting problem.
    run the fault codes
    indicates an idle control sensor or other throttle / accelerator sensors
    Nov 11, 2017 | 2005 Hyundai Tucson
    Starts and then runs wide open.
    SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
    May 19, 2009 | Husqvarna Chain Saw 20" Bar
    Garden Logo
    1,450 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
