When you push the ON Button it will not stay on.
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and re-plug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic of a bust capacitor (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on Sep 27, 2008
Roper dryer won't stay on after pushing start button. If I hold the button in it will stay running
YOU HAVE A BAD PUSH START BUTTON CONFIRM THIS BY TESTING WITH A METER FOR OHMS
Feb 23, 2015 | Roper Dryers
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
Push to start button will not stay on.
clean lint fromsafety switch no pay no stay
Oct 10, 2009 | Dryers
The interior lights stay on and the door ajar light is on when driving. the interior lights stay on when you shut off the car thus running the battery down. It happens about 70 percent of the time and when...
Find the lamp push button on each door.
Open one door, and only one door (or tailgate).
Push the lamp button IN at that door. If light goes out, then that particular push switch needs adjustment or replacement.
Cl;ose door and open another door. Push button IN.
Keep doing this until you find faulty door push button.
Which door was it?
Sep 24, 2009 | 1998 Lincoln Navigator
Toyota Avalon 1998 A/C Push Button
If when button is pushed in it stays in the AC-light lights up, then you may have another problem like a leak in the system N0/low Freon in system and AC would n't work. But if the switch doesn' t stay push in when its pushed then the switch is BAd and needs to be replace and that will solve the problem. If the switch stays push in with NO AC light on then you may have a bad Ac fuse. Good luck and thanks for using Fix Ya
Mar 18, 2009 | 1998 Toyota Avalon
Power button problems
The round button should light up when printer is on. Push it and the light goes off and so does the printer.
Jun 12, 2008 | Lexmark X2500 All-In-One Printer
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
