Question about Frigidaire Refrigerators
I have a fault code 4 on fresh food temp controll
  • 210 Answers
Whats the model # ?
Posted on Sep 27, 2008
What is the correct fridge temperature this fridge should be on?
If your refrigerator has 2 controls, the start setting is usually at mid point on both dials. That should give you a freezer temp close to 0 and a fresh food temp of 38 to 42 degrees. If only one control---same middle setting should produce about the same inside temps. Fresh food temp is best measures if you can put thermometer in a glass of water to stabilize the temp.
Apr 15, 2015 | Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
What should the temp be for freezer and refrigerator?
dont know model, do know temps. The fridges highest temp is 5deg c, preferably between 1 and 4, if freezer goes above minus(-)18deg c your are in danger zone, there should be a regulator control in the fridge, usually on left or right hand side near front(door)
Jan 25, 2012 | Kenmore Refrigerators
What temp should the frezzer be and what temp should fresh food side be
hello, the standard temps are zero in the freezer and 38 in the fresh food side. Hope this helps.
Jun 07, 2011 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Contact an appliance service company.
Feb 19, 2010 | Refrigerators
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
My freezer is working fine but by refrigerator is not working. how can that be with a maytag side by side?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 21, 2009 | Refrigerators
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites ( and may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Inability to adjust temp controls
5,6,7 is a fault code saying the defrost circuit is not working. The unit only goes into defrost about once a day so that explains why it works for a while then comes back.
Jan 21, 2008 | LG (LRBC22522ST) Stainless Steel
Refrigerators Logo
136 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
