Question about Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D
Hi, I was taking photos and suddenly my camera showed error message "err CF". How do I fix it and avoid losing the photos I'd already taken? All help gratefully received.
Thanks
Bryony
  • bry0ny Oct 17, 2008
    Hi Guys
    Thanks for the replies, much appreciated. In the end, I used all your suggestions! Doing so removed the error code to allow me to take one shot - but then the error code reappeared. I concluded that the CF card was fubar and I've bought a new one...
    The photos that were already on the card were recovered using a nifty bit of software my boyfriend has.
    Thanks again for your help.
  • Anonymous Dec 26, 2008
    the pins inside the memory slot are bent,can I still take pictures and how can I store them,please....Heeelp.....
    Problem Solver:
  • 4 Answers
This happens to me from time to time. I just take out the batteries and reinstall them and it seems to reset the problem. ALso try cleaning your lens contacts.
Hope this helps
Philip in Texas
Posted on Sep 29, 2008
Remove your cf card and check that the pins inside the camera are not bent and all atraight ..
Posted on Sep 28, 2008
  • 3 Answers
I don't have a 350D, and don't have a list of codes but I would guess the error code refers to the Compact Flash card. In the instructions to my camera, a 400D, the solution is to remove and reinstall the card, if there is still a problem, you might have to format the card. Hopefully this will help!
Posted on Sep 27, 2008
Error message reading Err CF
Be careful. I had the same problem, and for me it was a corrupt CF card.
Try reading the card on a card reader with your computer. If it can't read it, you'll need to replace it. Otherwise you could lose future photos.
I hope this helps!
Mar 06, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon error 99
.1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99' message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99' message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99' message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99' with a different Canon lens attached, then the
camera should be serviced.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt eos shows ERR CF. What do I do now?I tried a new flash card but still got the same error message. When I try to preview pictures I have already taken the screen says ¨no image¨. My...
Check that the pins in the camera that connect to the CF card are clean and not bent. You will probably need a good light and a magnifying glass to see into the card slot. If you can see a pin that is bent you could try straigtening it. BEWARE- turn off camera and use a non conducting "stick" ie cocktail or toothpick. Not sure for a Canon but a colleague paid £40 for a new pin assembly for a Nikon with similar problem.
Hope this helps.
Steve A.
May 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Hi, all of a sudden, my Canon Rebet XT gave me a faint flashing error 99 message. It won't turn off and the red light at the bottom right of the screen stays on even when I turn my camera off. I have to...
To isolate the cause of the issue, we suggest that you do the following:
4.clean all lens contacts on lens and camera with a rubber eraser
5. Insert a fully charged battery, and turn on the camera.
6. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
>from :
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
May 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CF Card Err
Sounds like you have bent pins on your CF reader. Open the door, take out the card and look inside. Is there damage to the pins?
You maybe able to fix it with pincers and a needle just align the pin or pins that are out of place, i did this and it worked for me and now my camera is working fine. and for free.
Good luck
Mattias
Oct 29, 2008 | Canon Rebel XT / EOS 350D Digital Camera
ERR CF
The pins inside the camera may be damaged. Use a flashlight to check inside the slot where the card goes
Mar 16, 2008 | Canon EOS Rebel G 35mm SLR Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
320 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
