Question about Lands Phones
Well i droped my phone in the water and now after drying it off it works but it says "Car Kit" on the main page of my phone.
    Sergeant:
    Champion:
  • 223 Answers
Believe it or not the phone is still possibly wet inside and its a very small amount of moisture shorting across something which is causing this spurious reading on the screen. There are a few ways to dry it out thoroughly, but I have always found the best method is to leave the phone on top of a radiator on a low heat setting for a couple of days and that usually does the trick. Please do not try to dry it out quickly by leaving it on a hot radiator or damage will surely happen to the phone. Good luck.
Posted on Sep 27, 2008
Dropped in water
That's really messed with water + electronics. Better visit a mobile repair center before you damage your internal chips. ;)
Jul 15, 2013 | Cell Phones
My phone has no sound, and it now says "-Car Kit-" WHY?
Firstly i come to your 2nd question where you asked what the meaning of Car Kit. Bro Car Kit means a sound system which contain also blue tooth, DVD, FM etc. So in Car Kit any one can pair their blue tooth devices i mean your cell phone where blue tooth are available. So when you pair your device at the define range then Car Kit will be connected with your phone so when your receive or dial a call then the Car kit speaker will be active automatically. You can hear voice from there.
Now come to your next question,
If your Car is off or you are so far from car then your speaker will be enable normally but if it don't work then means your speaker disable or inactive. As a result, you have to change your speaker by a expert technician then you will release from this problem. Thanks a lot
Nov 09, 2012 | Cell Phones
I droped my N70 in WATER...
remove battery, if not done already, let it dry, at least for days. drying faster, if you can open it somehow...
i hope fresh water, salt water means it will die whatever you try as the salt will destroy the circuit boards after some days.
Nov 25, 2010 | Nokia N70 Cellular Phone
I droped my fone in water and its in a screen and all it says is emergency download and im wonder how to exit it i took out my batter and put it bak it but it gose bak to the same screen pls pls help
take the battery out and let it dry for a couple of days should restart, but it has to be dry. if it is dry you should follow any directions it say to reload the phone...hope it helps.....
May 28, 2009 | LG Vu CU920 Cellular Phone
I droped my sidekick 08 n da toilet and iht wont work n0 MORE
If it's been over a month since this happened there's a good chance the circuit board was fried.
May 23, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Droped in water now it dosen't work
Try leaving it in a DRY bowl of rice over night. I'ved used that solution on a phone as well as an ipod. Both still worked after the water damage. Make sure the Sansa is completely covered in the rice though. It needs to be under for about 8 hours total. This will help remove any remaining moisture in the unit. After it is dry, if it still does not work; you have a hardware issue and will either need to get it serviced or replaced. I do hope this article is helpful to you though.
May 06, 2009 | SanDisk Sansa Clip MP3 Player
My lg vx8300 phone
Go to settings and change the normal mode and re staret the phone settings will actvate.
Jun 24, 2008 | LG VX8300 Cellular Phone
Motorola sliver
take it apart and let it all dry out i droped mine in my sink and then let it dry out it should work
Jun 23, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Cell pjone water damage
Turn your phone off for at least a day. Dry off your phone if you haven't already. Take out the battery, dry out the inside of the phone. If you have a sim card, take that out and leave to dry. Leave the battery out of the phone for a day as well. Put it back together after a day and try to power it on. If it doesn't come on, try plugging it in without the battery in. If it works that way, you simply need a new battery.
If this doesn't work you're probably going to have to get a new phone. Your cell phone provider will be able to tell if it's water damaged, so check with them to see if they replace water damaged phones.
Nov 30, 2007 | Samsung SGH-t629 Cellular Phone
I droped my phone in water, what shd I do. Could you suggest a service center for Motorola V3i in Noida or Ghaziabad, India.
You should have removed the battery immediately, open the cover case and dry it out. Do not insert the battery untill it is completely dry. In most cases, it works.
Well, if it is still not working, go to a service centre. Good luck.
Nov 13, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Lands Phones Logo
42 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
