Related Tags:
This problem should be removed because:
Problem with Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System
Code for Comcast remote for Sony DAVHDX275
I am setting up HD TV system with a Comcast Custom DVR3 Remote. I am using a Sony DAVHDX275 Home Theater System for the sound. I have been able to program the Comcast remote to control my Sharp TV but have not been able to do the same with the Sony 275. I have tried all the codes in the Comcast remote manual.
Can you help me determine the necessary code?
Solutions (3)
Best Solution
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
the mute code = 33743
Try the old 4 digit codes listed here: http://www.comcast.com/remotes/universal.html
just prefix it with a 1 (if the 4 digit code is 0000, use 10000). Worked for my Sony DAV-DX375 with the (1)1903 code.
Probably a little over 4 years ago when my old remote stopped working and I exchanged it for a new one. Imagine my surprise when the new remote wouldn't recognize my Sony DAV-HDX274 (Bravia home theatre). Luckily, the new remote worked okay with my other TV so I just swapped remotes. This old remote has been acting flaky for a couple of months now, so I can finally exchange it for a new one. Yayyyy! Thanks, foo8559!
I need device codes
I need device codes for sony DAV HD279w home theater/dvd player controlled by comcast digital cable remote control (none of the codes work...
comcast on demand custom dvr 3 device codes for...
I have a Sony DVD HDX576WF theater in a box and a comcast on demand custom dvr 3 device and the code listed for comcast do not work,...
Program a Comcast Custom DVR 3 remote for Samsung...
I cannot find a code for the Comcast Custom DVR 3 remote to control a Samsung HT-X40 system .. anyone have any ideas and/or the code ?? ..
i have a sony bravia davhdx274 but i no longer
I have a Sony Bravia 5-Disc DVD Home Theatre System (DAVHDX274) but I can't find the remote control for it. Can it be used at all...
Add Your Solution
my sony dav-hdx-267w plays some dvds and not...
if you put in a prerecorded disc it recognizes and plays some but not others. sometimes says "no disc"
Hi I am unable to program my COMCAST remote to
Hi I am unable to program my COMCAST remote to control my DAV-HDX275. I have tried all codes suggested by comcast in...
I have a DAV-DZ670M sony
I have a DAV-DZ670M sony music system. It is receiving power but keeps flashin the message "PUSH POWER...
I have use your posting
I have use your posting to tune the universal remote from comcast to my Sony receiver system but, What is the code for...
all speakers work,except the rear
all speakers work,except the rear two wireless speakers
See all Sony BRAVIA DAV-HDX267W Theater System with Problems
Fix-O-Meter
7,121
7,121 people viewed this problem
- 131 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Sony Home Theater System Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
How do I get the play, stop, ff, fr to work?
oh man! this is so great! thnx soooooo much!!!
Thanks!!! Worked on my Sony HDX576WF
