Question about Home
Installation plans needed
I was given a Jensen Air Masseur tub without installation plans.   It has a blower to connect - model T02-250-120/60-P2-J1.   Is there someplace I can find the plans for this.  My electrician does not know how to connect all the wires. Any suggestions would be appreciated.
    Novelist:
  • 171 Answers
Hi enamelcat,
I'm Harvey the Master Plumber.
Your problem is: You were given a Jensen Air Masseur tub without installation plans. It has a blower to connect - model T02-250-120/60-P2-J1. Is there someplace you can find the plans for this. Your electrician does not know how to connect all the wires. Any suggestions would be appreciated
I can usually wire this up myself, but any electrician worth his salt can figure it out. If you're having trouble finding such a person then you'll have to get in touch with the manufacturer to get an electrical diagram or instructions.
.Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
How to install a blower moter and fan
Well, here's the instructions from the service manual. The labor guide says this can be done in 1.6 hours...I don't see how, unless the instructions are wrong about having to remove the instrument panel. My thoughts are that if you are only doing the blower motor, the blower assembly will come out without pulling the dash. You probably only have to do a partial disassembly and remove the glove box and the glove box lower support.
BLOWER ASSEMBLY
Removal and Installation
1. Disconnect battery ground cable. Remove Instrument panel. (See Instrument Panel Removal) Disconnect resistor connector. remove blower assembly duct. Disconnect motor connector. Remove blower assembly
2. Remove blower assembly screws and blower motor assembly. Remove clip and fan from assembly. Separate motor case and remove blower motor. To install, reverse removal procedure.
INSTRUMENT PANEL
Removal
1. Disable air bag system. See AIRBAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT SECTION. Disconnect negative battery cable. Scribe mating marks on steering wheel and shaft for installation reference. Using Steering Wheel Remover (J-29752) remove steering wheel. Remove steering cowl.
2. Remove instrument panel grilles and plug, or driving pattern indicator panel (A/T Models). Disconnect electrical connections. Remove instrument panel hood, instrument cluster ezel and instrument cluster. Remove hood release handle. Remove knee protector.
3. Remove dash fuse/relay block and side trim. Remove engine control module box. Remove radio console and glove box lower reinforcement. Remove speaker covers and glove box. Remove heater control panel knobs and cover. Disconnect heater control cables, and remove heater control panel. Remove illumination control knob. Remove instrument panel.
Installation
1. Install instrument panel. Install and adjust heater control cables. To complete installation, reverse removal procedure. Ensure mating marks on steering wheel and shaft align. Apply grease to contact ring and tighten steering wheel nut to 26 ft.lbs. (35 N.m).
Feb 28, 2011 | 1995 Isuzu Rodeo
AC or heater fan does not work?
The most common problem with these fans are the fan itself wears out, or the relay becomes burnt at the contacts inside, or both.
Blower Motor REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. If necessary on 1992 and 1993 Typhoons, remove the charge air cooler. For details, please refer to Section 3 of this manual. Fig. 1: Example of a common blower motor installation - vehicles without A/C shown 85386001.gif
  3. Disconnect the blower motor cooling tube.
  4. Disengage the electrical connector(s) from the blower motor, as necessary. NOTE: On some earlier models equipped with A/C, it may be necessary to disconnect the A/C vacuum tank and move it aside.
  5. Remove the blower motor-to-case screws, then carefully withdraw the blower motor from the case. To install:
  6. Install the blower motor to the case and secure using the retaining screws.
  7. Engage the electrical connector(s) to the motor, as necessary.
  8. If moved on early model vehicles, reposition and secure the A/C vacuum tank.
  9. Connect the blower motor cooling tube.
  10. If removed on 1992 and 1993 Typhoons, install the charge air cooler.
  11. Connect the negative battery cable. Fig. 2: Disconnect the blower motor cooling tube 86616001.jpg
    Fig. 3: Disengage the necessary electrical connector(s) from the blower motor 86616002.jpg
    Fig. 4: Loosen and remove the blower motor retaining screws 86616003.jpg
    Fig. 5: Withdraw the blower motor from the case 86616004.jpg
Nov 19, 2010 | 1991 Oldsmobile Bravada
Need to replace heater blower motor. How do I get to it?
Behind the glove box. Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck, please get back to me.
See instructions from autozone.com below.
With Air Conditioning
See Figures 1, 2 and 3
  2. Remove the glove compartment door and glove compartment.
  3. Disconnect the blower motor wires from the blower motor resistor.
Fig. Fig. 1: Disconnect the blower motor wires from the blower motor resistor-1988 Escort
  1. Loosen the instrument panel at the lower right-hand side prior to removing the motor through the glove compartment opening.
  2. Remove the blower motor and mounting plate from the evaporator case.
  3. Rotate the motor until the mounting plate flat clears the edge of the glove compartment opening and remove the motor.
  4. Remove the hub clamp spring from the blower wheel hub. Then remove the blower wheel from the motor shaft.
Fig. Fig. 2: Unbolt the mounting plate from the case
Fig. Fig. 3: The motor can now be removed from the case
To install:
  1. If removed, assemble the blower wheel to the motor shaft and install the hub clamp.
  2. Install the motor and blower wheel assembly.
  3. Secure the instrument panel at the lower right-hand side.
  4. Connect the blower motor wires at the blower motor resistor.
  5. Install the glove compartment door and the glove compartment.
  6. Connect the negative battery cable.
  7. Check the system for proper operation.
Without Air Conditioning
  2. Remove the air inlet duct assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cable.
  6. Check the system for proper operation.
Nov 05, 2010 | 1989 Ford Escort
Air condition blower doesnt work in 2003 mercury grand marquis
Removal & Installation To Remove:
  1. Disengage the wire harness connectors from the retainer.
  2. Disconnect the blower motor electrical connector.
  3. Remove the hose.
  4. Remove the screws and remove the blower motor. CAUTION
    Clean any corrosion from the blower motor shaft before removing the fan.
  5. Remove the wheel from the blower motor.
To Install:
  1. Install the wheel on the blower motor shaft.
  2. Place the blower motor in the housing and install the screws.
  3. Connect the hose to the blower motor.
  4. Connect the electrical connector.
  5. Install the electrical connectors in the retainer.
Jul 30, 2010 | 2003 Mercury Grand Marquis
How do I replace the fan blower?
GM Celebrity/Century/Ciera/6000 1982-1996 Repair Guide
Blower Motor - REMOVAL & INSTALLATION
This procedure is applicable for vehicles, with or without air conditioning.
  1. Disconnect the negative cable at the battery.
  2. On the 3.1L (VIN M) you will need to remove the serpentine belt and move the alternator aside.
  3. For the 2.2L (VIN 4), disconnect the air inlet resonator, then remove the torque strut from the engine. Rotate the engine slightly forward.
  4. Working inside the engine compartment, disconnect the blower motor electrical leads.
  5. Remove the motor retaining bolts. If there is a hose disconnect it, then remove the blower motor.
To install:
  1. Position the blower motor on it's mount.
  2. Install the mounting bolts and tighten until snug.
  3. Attach the drain hose if removed, then engage the electrical connection to the motor.
  4. On the 2.2L (VIN 4), properly position the engine and install the torque strut to the engine. Connect the air inlet resonator.
  5. On the 3.1L (VIN M), install the alternator, if removed. Install the serpentine belt.
  6. Connect the negative battery cable, tighten the cable bolt to 11 ft. lbs. (15 Nm).
  7. Reset the radio, clock and any other applicable electronic devices.
Hope helps (remember comment this)
Jul 15, 2010 | 1987 Buick Century
How to install a front blower motor in a 96 ford explorer
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
How do i change the blower motor on a 1994 gmc sierra 1500 truck
GM Full-Size Trucks 1988-1998 Repair Information
Front
(see Figure 1)
  1. Disconnect the negative battery terminal.
  2. Mark the position of the blower motor in relation to its case.
  3. Unplug the electrical connection at the motor.
  4. Remove the blower attaching screws and remove the assembly. Pry gently on the flange if the sealer sticks.
Fig. 1: Blower motor wiring
  1. The blower wheel can be removed from the motor shaft by unfastening the nut at the center.
To install:
  1. Install the blower wheel to the motor shaft and tighten the nut at the center.
  2. Apply a bead of sealer to the blower mounting flange. Position the blower so that the marks are aligned and install the screws.
  3. Attach the electrical connection at the motor.
  4. Connect the negative battery terminal.
1991-98 C/K With Air Conditioning
  2. Remove the instrument panel compartment.
  3. Unfasten the forward-most screw in the right side door sill plate. Remove the trim panel from the right hinge pillar.
  4. If necessary for access, unplug the ECM wiring and remove the ECM.
  5. Unplug the electrical lead at the blower motor and if equipped, remove the underdash courtesy lamp.
  6. Remove the bolt from the right side lower instrument panel support. Remove the blower cover and the cooling tube.
  7. Unfasten the flange screws and pull out the blower motor. You may have to pry back the right side of the instrument panel slightly. Be careful!
To install:
  1. Position the blower motor and install the mounting screws. Be careful not to catch the blower on anything when sliding it in.
  2. Install the cooling tube and the blower shield.
  3. Install the bolt into the instrument panel support.
  4. Attach the courtesy lamp and the blower electrical lead.
  5. If removed, install the ECM. Attach the wiring harness.
  6. Install the trim panel on the pillar. Don't forget the screw in the sill plate!
  7. Install the instrument panel compartment and connect the battery cable.
Rear
1992-98 Models
(see Figure 4)
  2. Remove the right rear quarter panel trim.
  3. Disconnect the electrical lead at the fan.
  4. Remove the screws and if equipped, the cooling tube.
  5. If necessary, remove the fan retaining nut and lift out the blower fan.
  6. Remove the blower motor.
To install:
  1. Install the blower motor and then position the fan.
  2. Install the retaining nut and then tighten the mounting screws to 12 inch lbs. (2 Nm).
  3. If removed, install the cooling tube.
  4. Connect the electrical lead. Install the quarter panel trim cover.
  5. Connect the battery cable.
Fig. 4: Auxiliary heating and A/C system
Mar 31, 2010 | 1994 GMC Sierra
Connecting a mansfield whirlpool tub pump don't know the model number pump is in the floor and tough to get to. there are 2 cords hanging out. 1 male end and 1 female end. When I plug in the male end, the...
Hello Joe, Typically when you have a whirlpool type tub, there is either a built-in air switch on the tub that will turn the tub motor, on and off, or the tub needs to have a wall switch to turn it on and off.
The switch has to be located so it is at least a minimum distance of 3-4 feet from the edge of either a tub or shower stall, and it must be connected to a GFCI protected circuit. Normally any whirlpool tub requires a separate dedicated 20 Amp 120 Volt AC circuit for proper operation and to meet code.
I believe that the female plug is for an optional, in-line heater that can be installed into the tub unit. You should be able to check the installation manual that came with the tub to verify the proper wiring required for your specific unit and model.
I would contact the manufacturer to get a copy of the installation guide and instructions for your model, so you are certain that it is properly installed and the wiring you are using meet the NEC (National Electric Code).
Here is a link to the Mansfield web site with some FAQ's and their phone contact information.
http://mansfieldplumbing.com/v3/support02-03.html
I hope you find this Very Helpful and best regards!
Dec 11, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Aug 16, 2009 | Home
GE Stove
I'll need a model number to determine what's going on and whether the part is really a generic. They should have given you some kind of installation instructions.
Dec 24, 2007 | Kitchen Ranges
Home Logo
218 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
