Our washing machine is only about 3 years old and it has started leaking from the left hand side down the bottom on the washing machine. It doesnt appear to be any pipes, it's coming from the actual machine
  • Jess09 Sep 28, 2008
    hi
    it's a samsung SW6IASP. we've only had it for about 3 years and it's only been used for about 2 1/2 of that. I really dont want to have to buy a new one!!
    Thanks
  • AlmostBob
    AlmostBob May 11, 2010
    what kind of machine
    make and model it makes a difference
  • 550 Answers
Usually in a samsung
the pipe from the drum to the pump
inside the machine
comes away from the drum
the pump end is secured with a clamp
the drum end is a push fit
there is glue on the push fit end
but the amount is miniscule
Silicon adhesive: Contact Cement: glaziers glue: all work
the model number given does not show in my samsung lists so I cant give you exact instructions for accessing the pump hose, nor can I be certain that this is the exact fault
Not a solution, but somewhere to start
Posted on Oct 29, 2008
My westinghouse leaks water. It's 16 years old, so if it's some major problem I'm ok with it and I'll get a new clothes washer. On the other hand I would like to open up the washer and
The back and sides are one piece. The front comes off (two clips under top, one on each side about 2 or 3" in from outside - two screws on bottom directly below clips). The top will lift up on the rear hinges, the front lifts about 0.5" and comes off.
Aug 02, 2012 | Westinghouse WWS833ES Super Capacity Top...
My Frigidaire GLTR1670A front loader hot and cold
sears parts direct carries a lot of parts can be accessed online can start there or just search for frigedaire part number
Dec 10, 2009 | Frigidaire GLTF1670A Front Load Washer
KitchenAide Dishwasher KUDS01FL leaks water
i have had mine leak (usually out of the left side) I can see it coming off the black rubber seal that ends about 2/3 of the way down the side. ( I have also replaced the inner seal around the tub- that helped as the bottom of the seal would stick to the door when closed and make a gap for water to come out) I also notice that water and moisture comes out at the top of the dishwasher (then it leaks down the side and front) I have heard of many problems with the latch...and I can push mine closed tighter but it doesnt close completely with just the latch, but enough for the wash cycle to work. also just make sure there are no crumbs or something stuck around the liner. good luck mine has been a lemon and i cant wait to get a different brand.
Jun 18, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Leak
Hi, If you remove the lower half of the front panel, you will be able to see the pump and hoses. Another option is the bellows around the door. Please let me know if this helps or if I can assist you further.
Thank
Vic
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer fills with water but will not complete the cycle. Since it started this, it did finish 2 or 3 loads sporatically, but doesn't seem that it will even do that now.
We had the same problem. Luckily, we bought a 3 yr extended warranty. The appliance tech came in, pulled out a screw driver and tightened the lid. He said the left side frequently comes loose and that is where the sensor is that tells the machine the lid is closed. Tighten up the lid and see if that solves it. This washing machine BLOWS. We have had the warranty people out 4 times since we bought it. It's only two years old. First there was no hot water, the tech opened the machine and the connecter to tell the machine to use hot water was never connected at the factory. Water leaking from the bottom, don't remember what that was. Oil leaking from the bottom, replaced trnsmission seal. Fills with water and stops, loose lid. What a lemon.
Mar 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore HE 3t started leaking from the side when filling
check dispencer and make sure its not cracked,,if not turn your water pressure down to the dispencer its splashing up and over running down..keep me posted onthejob
Jan 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Leaking Water
if there is a clamp on there try tightening it up or put a new clamp on it
Mar 25, 2008 | Washing Machines
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Sep 20, 2007 | Dishwashers
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
