Question about Sony Ericsson Walkman W810i Cellular Phone
Arrow failure All the buttons on my phone work apart from the arrows. for some reason they are no longer working and neither is the play/stop button. any ideas what i can do to sort this out?
  • 94 Answers
Wicabix hello,
It seems like the keypad has moved perhaps because of a trauma to the phone.
I would suggest to send it to a lab if still under warranty.
If not, open the back lid, remove the battery. Then, unscrew both panels using a small screwdriver, and try to place the keypad in its right place.
Then, screw back on, put the battery in its place, and turn the phone on.
Good luck.
Posted on Oct 29, 2008
Casio Exilim EX-P505 the left arrow key doesn't work. is it setting or broken? what should i do?
Most likely the arrow key switch is broken or the contacts are corroded. If it's a snap-button switch, it needs to be replaced. If this is bad, I recommend replacing the others also. If it's a conductive rubber button (like most TV remote controls), the conductive patch on the inside is worn and needs to be repainted with carbon/silver conductive paint. A miniature snap-button switch is generally less than a dollar from Mouser Electronics - soldering skills are required for replacement. Conductive paint for rubber button switches is $10.45 for a 1 gram tube. It has a very limited shelf life once it's opened, so use up the rest on the other camera buttons, and the power, channel and volume buttons on your favorite TV remote control (if you can get it apart without breaking the case)
Cameras are typically difficult to take apart for repair. You'll have to consider the value of the camera versus the effort to get to the control buttons. The electronics inside are sensitive to static electricity damage, so you should work on an anti-static mat and use an anti-static wristband with it..
Nov 14, 2017 | Casio Exilim Pro EX-P505 Digital Camera
No sound
Here is a possible solution to this problem, assuming the DVP5982 is connected to the tv with an HDMI cable.
Press setup on the remote control of your DVP.
· Go to the Audio Setup icon with the right arrow button
· Press the down arrow button to select DIGITAL AUDIO SETUP and press the right arrow button.
· Go to DIGITAL OUTPUT with the cursor buttons and press the right arrow button.
· Go to PCM ONLY with the down arrow button and press OK to confirm
· Press setup to leave the menu.
The DVP5982 will now send analogue stereo audio to the tv.
Feb 11, 2008 | Philips HTS3450 System
Hi, My Samsung DVD player remote would not respond when power button pushed on. When DVD power turned on Manually and DVD loaded the remote would not respond to the play, arrow buttons eirther?? My LG...
If the buttons on the case are working but the buttons on the remote don't then it's clearly a fault with the remote.
Each button in the remote is made out of 2 wires on the electronics board that are joined by a small patch of conductive paint situated on the rear of the rubber button. If something gets in there, like water or dirt or the patch flakes out, the contact is no longer made and the button no longer works. The remote will have to be dismantled by popping the clips on the periphery with a sharp tool, the rubber strip holding the buttons will have to be washed and the board wiped clean. If the buttons still don't work after that then the remote is dead, you will have to get another one.
Jul 24, 2011 | Televison & Video
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
The dvd drive in my Compaq CQ60 laptop stopped working after a few months. It will no longer play dvds cds or function with any information disks. I want to upgrade from Vista to the W7 os I have the disks...
try to click this program:
start > type run then hit enter
> then type regedit , then click OK
> click the arrow HKEY_LOCAL_MACHINE
> click the arrow SYSTEM
> click the arrow CURRENT_CONTROL_SET
> click the arrow CONTROL
> click the arrow CLASS
> click the folder 4D36E965
uninstall UpperFilters and LowerFilters
restart pc then insert the DVD if it will play......
May 09, 2010 | Computers & Internet
Some buttons have stopped working the menu down arrow button zoomhave stopped working and the situatiob is worsening
Your great little camera is indeed sick, sounds like dirt or liquid got inside the button area. I suggest downloading the manual, and if it looks like something you are capable of and have the time, taking it apart and cleaning it, if you are not successful you are not out much as it was already not working, with the possibility of success! if dirt or water got this far it may be going for other parts also, so inspect carefully, about half the cameras I've had apart are repairable within reason. Amazon has these for;
new from $129.95
4 used from $40.00 Hope this helps
Apr 29, 2010 | Fuji FinePix F460 Digital Camera
Problem with MP3 player-Stops after one song
On closer look (after my long road trip to test this out), I realize when you hit Browse, there's a button on the bottom titled Play All. If you select this button, the buttons mentioned above work as intended, and the Forward, Backward buttons bring you to the next or previous songs in the list.
Sep 27, 2008 | Garmin Nuvi 660 GPS Receiver
Wheel and buttons not working
theres possibly some water in there, Id recommend takeing the ipod apart and drying very carefully so there is no water anywhere. you can use a hairdryer also.
but thats after you have the circuitboards and others apart, make sure you dont break anything while opening
http://www.youtube.com/watch?v=HRjLszFoNxU
dont get it too hot.
Apr 17, 2008 | Apple iPod nano
Couple buttons stopped working
you could try taking it apart then clean it out ie dust or sand but i recently took my old phone part like yours and decided its easier to buy someones broken phone(ebay) like yours with a cracked lcd or something and use the key board from that phone to yours.
Jan 13, 2008 | Samsung SGH-d807 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
26 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
