Am trying to connect to the internet using my current computer and am getting no flashing light or connection to the internet although it says the modem is installed correctly on com port 3 when i have a look at the hardware profiles it doesn't show a com port 3.....help!
  • 4,338 Answers
In the control panel, device manager, remove the com ports then the modem. Restart the computer and the OS will reinsatll the com ports and the modem should be on a good port 3.
Posted on Sep 27, 2008
How do I access internet..desktop trough laptop
You need to share them into a homegroup together.
Or are you using a crossover cable? U cant just use notmal cat5 cables to connect a computer to a computer.
Although, why on earth are you trying to access the internet through another computer?
The whole idea sounds disasterous.
Maybe get a wifi card for desktop if its a distance issue.
Sep 04, 2016 | Computers & Internet
The wireless router/AP for your network is working, but your computer is not able to use an IP address to connect to the Internet. You will not be able to connect to the Internet, although you might be...
Check lights on the router and make sure they are on where applicable. Also unplug it for 5 minutes and plug in again the wait 10 minutes to try connecting and give the device lots of time to try and connect. If you haven't already plug it directly in with one of the Ethernet cables, or make sure your pc / computer / device is on auto DCHP and so is the router. if you are using a ipad or tablet try another device or reset the router using the button on it.
Nov 30, 2017 | Dell Inspiron Computers & Internet
My wireless internet stopped working. i have model #wrt54g v8. i have cable internet also. when the wireless stopped working cable company checked said everything on there part is fine. its pluged in. the...
When you plug in the ethernet cable the corresponding numbered indicator on the router should flash to indicate a LAN connection and some data flow from the router to the computer. This does not necessarily mean that there is data flow from the internet to your computer via the router. Simple check would be to use a smartphone and try and connect to WiFi on the router but restart the router first. If the smartphone is also having problems then the problem may be with your internet provider or the router. If the smartphone connects then restart the computer. If the computer still does not connect then try the following steps to refresh the computers IP address:
For Windows XP
Step 1
Click Start->Run, type cmd and press Enter.
Step 2
Type ipconfig /release at the prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the prompt window, press Enter, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows Vista& Windows 7
Step 1
Click Start on the task bar, type cmd into the search box and press Enter.
Step 2
Step 3
Type ipconfig /renew at the prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows 8 & Windows 8.1&10
Step 1
Press windows key and X key at the same time. Then click at Command Prompt.
Step 2
Type ipconfig /release at the Command Prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the Command Prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
Hope that helps.
https://fastproactiveit.com/
Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Sep 22, 2017 | Linksys WRT54G Wireless Router
I am trying to update drivers online for devices that are on my computer, and am connected to the internet, but right at a crucial moment when the programme that I am using to help update out of date...
Provide the make and model number of you computer, the current version of windows you're using and tell me what drivers you are trying to update. Let me know at "add a comment"
Dave
Mar 27, 2011 | Computers & Internet
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
I am installing this wireless router into my new residence, but during the installation process I cannot get the router to detect an active internet connection. I am currently using the internet through...
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Sep 24, 2010 | Linksys Wireless-N WRT150N Router
The wlan doesn't work-it used to until last week! The flashing amber light on the front is completely gone and does not flash anymore! and it says that NO wireless networks detected - although my friend's...
1. check with you ISP. You may have an issue with the server.
2. check the connection in the router (router status) using 192.168.0.1 then enter "admin" and a password if used.
3.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 10, 2010 | Acer Aspire 3000 Notebook
No internet connection
re-install all network drivers or uninstall all network drivers and install again the drivers
Apr 05, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
How to flash my dcm425 cable modem
Ive never heard of flashing a modem before. A router you can.
Who is your ISP provider? They can get you a new modem.
Sep 04, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
Computers & Internet Logo
David Payne
David Payne
