Question about HP Computers & Internet
I have a hp pavillion 710 pc when it is plugged into the mains supply the power light comes on for a second and then dies out,would this be the power unit which I plug into
    Problem Solver:
  • 6 Answers
I think I had this same problem once before. It sounds familiar but could use a few more details as to exactly what happens. From what you have said so far though it sounds like either the main power to the PC is switched off, or your power supply for the machine might be bad. First I would try looking in the back of the computer. On some of them there is a little switch usually towards the top that allows you to turn the computers power on and off. If you plug into the wall it usually will come on for a second before turning off and then when you go to turn you computer on if the switch in the back is off you computer will not start if you use the normal power button in the front. I hope that fixes your problem. If that is not the case please give me a few more details on it and I will do my best to help you get to the bottom of it :). Good luck.
Posted on Sep 27, 2008
My HP pavillion a 1630n will not turn on no light or anythhing
When there are no lights, test the power cord and your mains power socket, if these are OK then your switch mode power supply has failed.
You need to remove this power supply, take it to your friendly computer repair shop and get it tested, if it is faulty then replace it with a new one. Make sure the wattage is the same or higher than the faulty power supply..
May 09, 2011 | HP Pavilion a1630n PC Desktop
My hp pavillion dv4-1220us laptop, won't start up...I press the power button and it turns on for a couple seconds and then turns back off....
1) Is it the battery, power up using the power supply.
2) When the power supply is plugged in, is there a charge light/led (could by a bad power supply not charging or providing a good connection)
3) Is the CPU over heating? Check the vents underneath are they clogged with dust?
After this, you're getting into internal faulty component issues and need someone to look at it.
Apr 13, 2010 | HP NB199UA Pavilion Notebook
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
I can not start my PC. It does have a green
Sounds like a defective power supply. Improper power coming from the supply will cause a unit to fail boot. Power supplies are about 40 bucks.
Oct 01, 2009 | HP Pavilion Media Center a1330n - AMD...
HP Pavillion 400 Power switch problem???
Could be your power supply is broken. That is a very common problem. Sometimes the computer will keep on restarting when the power supply is about to give way. I doubt it's the motherboard that is causing the problem, but then again i have never had a motherboard fail on me.
May 03, 2009 | HP Computers & Internet
Hp pavillion dv7 won't power on
Same issue - solved by disconencting everything (main battery, CMOS battery, RAM, hard disk and wireless card). Held in power button for 20 seconds (HP say this removes any electostatic charge on the main board). Reconnected everything and machine booted to Windows. Ran HP's onboard diagnostics and everything checked out OK.
Mar 30, 2009 | Computers & Internet
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
